Tom's Hardware > Forum > Audio > Audio Technology > Speaker Foam Surround or Voice Coil Problem?
Forum Audio : Audio Technology - Speaker Foam Surround or Voice Coil Problem?
Archived from groups: rec.audio.tech (More info?)
Recently, I started hearing serious bass distortion on my vintage JBL
L112 speakers. I inspected them and found that a couple of sections of
the foam surround had disappeared (about 10-percent of the total
circumference) on both the left and right woofers (12" 128H).
Will re-foaming the speakers eliminate the distortion, or is it likely
that there is voice coil damage? And what exactly is voice coil
damage? Is it an alignment issue or does the coil of wire actually
wear out? I'm kind of surprised that the relatively small amount of
missing foam would cause so much distortion. I rarely drive the
speakers to more than a "moderately loud" level.
Suggestions welcome.
Thanks,
Art Harris
Sponsored Links
The voice coil bobbin is rubbing on the center pole of the magnet. Remove
the dust cap wit acetone and shim the voice coil with four pieces of paper
of suitable thickness. Credit card works sometimes. Replace the foam and
let he glue dry thoroughly. Only than remove shims and replace the dust cap.
Stay a light year distance away from any ferrous filings. There is plenty of
info on DIY foam on the web. I bought 12" foam rings for $4.00 in Toronto.
Regards,
Boris Mohar
Got Knock? - see:
Viatrack Printed Circuit Designs http://www3.sympatico.ca/borism/
Reply to Anonymous
"Boris Mohar" <borism@sympatico.ca> wrote in message
news:j7e5p09orp0pkrrf63882ggk3pjp2doevq@4ax.com...
paper
and
cap.
of
Toronto.
Another method that frequently works:
Replace the foam. Foam replacement kits come with shim material to center
the voicecoil while glueing.
After you're done, remount the speakers rotated 180 degrees. The gradual sag
of the spider from the force of gravity is now reversed.
Reply to Anonymous
There are 1166 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
