New Graphics Card Help
I'm having some trouble choosing a good GPU for my system. I'm looking for a good GPU in the £130-£200 price bracket but will also run on my Seasonic G550w PSU.
Specs are i5 3550, 8Gb Corsair RAM, 1 x 120Gb SSD, 1 x DVD/CD Drive and 3 x 120mm fans plus the G550 PSU.
I've been looking at the Radeon 7870 or the GTX 660 Ti, but I'm unsure if my PSU will be ok with either?
I'm looking for advice on a good gaming GPU that will not be too much of a stress on my PSU all the time?
Thanks
More about : graphics card
Graphics card Master
Your psu is of excellent quality. It has reserves past it's 550W spec.
It is capable of running a graphics card as good as a GTX680 or 7970.
Other pc components are trivial in comparison to the graphics card.
You are good.
On the 7870 or GTX660ti, benchmarks will show virtually equal average and minimum fps numbers, but I suspect that the GTX660ti may provide smoother game play.
Read this article: http://techreport.com/review/23981/radeon-hd-7950-vs-ge...
magnetica said:
Yea I really had my eyes set on the 660 Ti as it's a better card and only £30 more.
Once question though, will the PSU be stressed at all? I don't really want to push it too close to it's limit.
No, the GTX660ti is one of the newer 28nm based cards that are more power efficient. It will run with a 450W psu.
Related ressources
magnetica said:
Nice, thanks for your help I think I'm going to go for the 660 Ti.
One other thing, this card has 2 x 75w 6 Pins, should I plug in both? I know some cards can run with just the one.
Again, many thanks.
The card has two 6 pin connectors because it needs them. Plug them both in.
Your psu has 6+2 connectors, just leave the + 2 dangling.
The psu is capable of delivering 150W to each of the 6+2 leads, and you will, at max be using only 75w from each.
The second one is a supplementary as in theory the card could run on just one but its not a guarantee that the PCIe slot of every motherboard is going to supply a clean 75w.
