Got an problem with Quake 3 and my Geforce 2 MX400 64MB vid card. AMD 1.4GHz, 512MB DDR, Win98SE with all updates, Detonator 4 XP drivers, and the three patches I could find at the Quake site.
Installs fine but when I try to play I get this long error message.
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
C:\Program Files\Quake III Arena\baseq3\pak6.pk3 (64 files)
C:\Program Files\Quake III Arena\baseq3\pak5.pk3 (7 files)
C:\Program Files\Quake III Arena\baseq3\pak4.pk3 (272 files)
C:\Program Files\Quake III Arena\baseq3\pak3.pk3 (4 files)
C:\Program Files\Quake III Arena\baseq3\pak2.pk3 (148 files)
C:\Program Files\Quake III Arena\baseq3\pak1.pk3 (26 files)
C:\Program Files\Quake III Arena\baseq3\pak0.pk3 (3539 files)
C:\Program Files\Quake III Arena/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: maintower.wp.shawcable.net
IP: 192.###.###.###
Working directory: C:\Program Files\Quake III Arena
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...38 PFDs found
...hardware acceleration found
...PIXELFORMAT 8 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...using GL_S3_s3tc
...using GL_EXT_texture_env_add
...using WGL_EXT_swap_control
...using GL_ARB_multitexture
...using GL_EXT_compiled_vertex_array
...WGL_3DFX_gamma_control not found
Reinstall the 1.30 patch for q3a. Should clear up the problem. Otherwise do a reinstall of quake. The problem you have can be caused by a 3rd party user interface that was designed for an older version (arenaspy is a common culprit).
Looks like you are running a really old patch of quake.
yep, the last line gives you the info thats needed, if reinstalling the patch doesnt work (which it should), I complete uninstall/reinstall of the game followed by the patches will sort it
