Been running my 3 display setup for about a week now. Today I finally got another Dell 1905FP monitor so that I would have 3 identical monitors in my 3 display setup. I love it.
The one problem I have is the wallpaper setup is screwed up. I know this is not a big issue just a nagging thing that I believe has an answer.
When I setup the wallpaper so that it is one image expanded across the 3 monitors the image is out of order.
The monitors are configured correctly, If I place the mouse on the left most monitor and move it to the right the cursor moves seamlessly from left to right across the left, then the middle and finally the right most monitor. Just the way it should. But, the wallpaper starts on the middle monitor, extends to the monitor on the right then continues on the left most monitor.
The strange thing is when you go into the Windows 7 setup, it shows monitor1, then monitor 2 then monitor 3 in the correct order but if you go into the AMD Vision Engine Control center it shows the monitors in the following order: 3 - 1 - 2, and this is the order that the wallpaper is being applied. As opposed to 1 -2 - 3, the order displayed in the Windows-Control panel Display settings.
Check out the photos below.
At the end of the day, I can live with it but if there is a solution, it would be nice to fix it.
3 Monitor Setup:
What Windows Sees:
What AMD Vision Engine Control center Shows:
3 Monitor Setup:
What Windows Sees:
