MN-500 Port Forwarding Need Help!
Forum General Networking : General Gateways, Routers and Firewalls - MN-500 Port Forwarding Need Help!
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I just purchased the MN-500 so that I could go wireless.
Prior to that I was using a Linksys befsr41 Router. (for
future reference the 2 won't work together) On my
previous router I had port fowarding enabled so that I
could run a website of my pc for the purposes of my side
business. (been using it for almost 2 years no problems)
Now I try to set up port fowarding with the MN-500 and I
am unable to bring up the site. Is there a step by step
process I can go through to make sure I'm following all
the right steps? btw- I'm using XP with IIS and I am
able to ping the addy from my server but that's it.
Tnanks,
Chuck
Sponsored Links
Hi,
Go to your Base Station Management Tool, then go to Security, then click on
Port Forwarding then click on the Set up persistent port forwarding.
Then type in the following:
Put a checkmark box on the enable checkmark box then
Description: Web Server or (whatever else you want to name it)
Inbound port: 80-80
Type: TCP
Private IP address: the IP address of your internal computer
Private port: 80-80
This is assuming your IIS web server's port is on 80, if it's something else
then put in the respective port number in the inbound and on the private
port
Then scroll down and hit the Apply button.
Then try it out to see if it works.
Gary Tsang
Microsoft MVP - Windows XP Shell/User
http://www.microsoft.com/mvp
"Chuck" <anonymous@discussions.microsoft.com> wrote in message
news:1a8f601c42392$7eec4fb0$a601280a@phx.gbl...
> Tnanks,
> Chuck
Reply to Anonymous
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > MN-500 Port Forwarding Need Help!
There are 452 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
