Tom's Hardware > Forum > Home Cinema Equipment > Ptv Tivo > HR10-250 HDMI problem
Forum Home Cinema Equipment : Ptv Tivo - HR10-250 HDMI problem
Archived from groups: alt.video.ptv.tivo (More info?)
I have heard some of these arrive with dead HDMI outputs, but this is
different. I just got the unit, new, and HDMI works, but the output is
badly red shifted. If I use the component (? - three color lines) output
the signal is great. I have a Samsung HD tuner and it is great on HDMI, so
I am sure it is not the TV. Is this an example of a bad HDMI output or
something else? Is it adjustable or do I need to get another unit? I don't
know the manufacturing date, but the serial number is 3570000D0263D26, if
that helps.
Sponsored Links
In article <426f9e9a$1_3@news.nauticom.net>,
> that helps.
Somebody suggested by mail that the cable might be bad. I was going to
try to connect it to another tuner I have but it is DVI not HDMI. I
could buy another cable but I thought I would wait to see what others
suggest.
Robert B. Peirce, Venetia, PA 724-941-6883
bob AT peirce-family.com [Mac]
rbp AT cooksonpeirce.com [Office]
Reply to Anonymous
In article <bob-750C5C.21090327042005@news.verizon.net>,
> > that helps.
> suggest.
The cables that are $120 at CircuitCity are $10 on eBay
Reply to Anonymous
And then one day Robert B. Peirce said,
> that helps.
Robert -
If you're using this with a Sharp Aquos LCD set, then this is a known bug.
If you switch the HDTivo to a non-HD channel and hit the Ratio button a few
times, the pink screen will eventually correct itself. Alternatively, you
can use the Sharp remote, navigate to the digital menu, and scroll through
the choices. It eventually corrects itself.
Dave
Reply to Anonymous
In article <BE9A5E73.51A59%dave@leonlaw.com>,
I am using it with a 32" Syntax Olevia, but I tried it anyhow. No joy.
Still, that may indicate the problem is not in the Tivo itself but in
how it interfaces to the TV. Has anybody else seen this with a Syntax
32"? If so, what did you do to correct it?
Reply to Anonymous
In article <bob-994CE6.11411606052005@news.verizon.net>,
Problem could be output of TiVo, input of TV, or cable. And a $10 Cable
from eBay is just as good as a $129 "Monster" Cable from CircuitCity.
Reply to Anonymous
"Robert Peirce" <bob@peirce-family.com.invalid> wrote in message
news:bob-750C5C.21090327042005@news.verizon.net...
output
so
don't
if
> > that helps.
> suggest.
I spoke to DirecTV over the weekend and they think it is the DVR. They are
sending a new one for me to try.
Reply to Anonymous
There are 604 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
