How much power do I need?
4-6 Case fans
Pentium IV 2.53
Intel I850E Tehama
1GB PC1066 RDRAM
GF4 Ti-4600
DVD-ROM
CD-RW
Floppy
4 PCI cards
I was going to use 431W, but I figured that many case fans would require more power?
The case I'm looking at is the Directron 201B. Many case fans, but the only thing I'm going to overclock is the video card (hence the side hole).
Thanks
<font color=blue> There's no such thing as hell, but you can make it if you try.</font color=blue>
5 answers Last reply
More about power need
  1. 431 Watt will be enough but make sure you get a brand PSU.
  2. Maybe this <A HREF="http://www.pcpowerandcooling.com/products/power_supplies/selector/index.htm" target="_new">power supply selector</A> would help you out. (Courtesy of PC Power & Cooling)
    <font color=red><A HREF="http://www.btvillarin.com" target="_new">btvillarin.com</A> - My Windows XP-based Website</font color=red>
  3. Deffinetly nothing lower then a 431w Enermax, If you plan on adding some more stuff in the long run, i would go higher, something in the 500's
    This Community is like a Second Family!!
  4. Another vote for Enermax.
    Rob
    Please visit <b><A HREF="http://www.ncix.com/canada/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/canada/index.cfm?affiliateid=319048</A></b>
  5. Assuming you're using two hard drives, 350W should do. Extra power is always nice, so the 431W unit sounds like a good choice.
    What's the frequency, Kenneth?
Cases Power Components
