Nvidia geforce gtx 660 dual monitor display issues
Arkadious
Hello,
I have a geforce gtx 660 card with a dvi attached samsung monitor (SMBX2331), and a hdmi attached 46in samsung led television.
Everything works fine, i can get displays on both. My problem is that i would like to play games on the television, and have my taskbar, desktop and what not on the monitor while i play them. I'm trying to play the new 2013 release tomb raider this way, and cannot seem to get it working unless u run mirrored display where the game shows on both screens not just the television, any ideas?
I've tried opening the game in a windowed full screen mode, but it shows on my primary monitor only, and will not display on the television. I'm using a razor tournament edition xbox controller through usb to play games on the tv.
13
answers
Last reply
More about nvidia geforce dual monitor display issues
There are quite a few third party software to get your taskbar on both screens but there is no built in way in windows 7. But they did add it in w8. http://sourceforge.net/projects/dualmonitortb/
The game goes blank when move it to the second screen? -
yes, that is what im wanting. I want my monitor to be primarily for just desktop, skype, ventrillo, surfing the internet and what not with sounds from skype/vent coming through a wireless headset while i play games on the tv. Then i want games to play on the television, sound coming through the tv/surround setup. i had the sound worked out for a little while where i had only desktop/skype/vent coming through the wireless headset and only tomb raider gameplay sounds coming from the tv just like i wanted it, but while this was working i had tomb raider playing on both the monitor and tv at the same time, instead of just the television. Is this possible through windows 7, or like suggested is the only way through software?
ok so i have it on extended, made the television the primary so the games load up on that like i want. my desktop, skype, interenet etc are on the monitor like i want. Now the only problem i see is that the game sounds will only come through the headset. My headset is on and it comes through them, when the headset is off i get no sound, i cannot get sound through the tv/surround this way now. the only way i had sound on the tv before was on mirrored dual monitor setting im pretty sure, is there not a way to switch between headset and tv as i please on extended dual monitor setup?
basically my idea seems simple but the process seems impossible, maybe it just cannot be done.
I want my monitor to be my pc for normal pc processes. I want my wireless headphones to be the primary sound device for my pc/monitor.
I would like to have my HDMI connected samsung led tv as my gaming screen, and have game sounds come through the tv/surround setup. Practically using steam and my PC as a console with the tv as my display for this "console".
I would really like to be able to play games on the tv, with the game sounds on the tv, while wearing the headset connected to the pc, and talk on skype while playing games. I could look to the monitor to see chat, search the net and what not while not interrupting the games on the tv aside from switching tasks.
Maybe this just cannot be done, but if there is a device, or program that would allow dual monitors, dual sound devices to run simultaneously i would love to find out how its done. Again thanks for the replies, i feel like im making progress non the less. -
I think you would then need to go into your playback devices within your sound options and change it to the HDMI cable that is going into your TV because HDMI can carry over audio.
I don't think what you are asking is out there. I think you are asking for realistic things. I just think you need to find out what HDMI cable is going to your TV and then set that as your default HDMI cable because I think with how you have it setup its probably defaulting to your computer monitor.
Related Resources
Nvidia
TV
Geforce
Graphics
Related Resources
- GeForce FX5700VE display problem
- How to play with Dual Display ?
- GeForce 8800GT / Samsung LN26A330 quality problem
- AVI to HDMI from NVIDIA GeForce 6600 GT not working
- Nvidia geforce gt 440 dual monitor problems
- Geforce 8800 gts no display on monitor
- No display with Nvidia GeForce MX400 monitor blinks
- Geforce GTX 465 won't display second monitor
- Dual Monitors: GeForce GT 520 failing with TV monitor?
- Monitor as TV
- Geforce 8400gs dual monitor
- Geforce 8800GT dualview problem
- Nvidia Geforce 9100 issues
- GeForce GTX260 for use on 32" LCD TV?
- Nvidia Geforce 7600 GT to TV issue
