Help me choosing a GPU
DComander1x
536
If budget isn't an issue, you can skip the 680s and go with a Nvidia / EVGA GTX Titan, as its faster then those two 680s, or go with a Nvidia / EVGA GTX 690, which is two 680s on a single card, Though a 690 will need a PSU upgrade to at least 850w.
I would buy neither. They both are factory overclocked cards with boost clocks of 1137 and 1176. Hardly a distinction.
Both have the type of coolers that recirculate the hot air inside your case.
I might pick a EVGA GTX680 card with a direct exhaust cooler. The boost clock of 1150 is virtually the same and all the hot air will exit the case directly.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130779
If price is no object, then the Titan that DComander1x referenced is as good as it gets.
