Does anyone know if the "Advanced Resolution Stereo (96 kHz/24-bit)"
listed on the disc content of a DVD-Audio is something distinct from
the multi-channel content? I am playing "Bach Organ Spectacular" with
Ton Koopman on my Panasonic S97 DVD player (which supports DVD-Audio),
and when I press "AUDIO" on the player's remote a menu comes up on the
TV listing two tracks, 1 and 2. Track 1 has a check mark next to it
and is labelled "PPCM 96kHz 24bit 6ch," and 2 is not checked
(regardless of whether I select it) and has no label. My player says
"D.MIX" on the front panel no matter what I choose, and I can't hear
any difference when I try to switch between the two tracks, so I
suspect what I am hearing is always a downmixed version of the
multi-channel content. Is "Advanced Resolution Stereo" supposed to be
something other than the downmix? How do I select it? I don't want to
miss out!
Thanks in advance for any ideas.
MDeB
p.s. I do not check mail at the above address.
> Hi,
When available, it is distinct.
> miss out!
> MDeB
I believe that the 2-channel high-resolution "track" is optional. It
sounds like it isn't there on your disc. Or it could be there but
you're having a player setup problem.
Randy Yates
Sony Ericsson Mobile Communications
Research Triangle Park, NC, USA
randy.yates@sonyericsson.com, 919-472-1124
Thank you for the reply. I apologize again for the duplicate thread.
I tried to delete one but could not. I'm going to post to the other
one, and to avoid confusion should we consider this one terminated?
Thanks again!
Thanks again!
Thanks again!
