View source problem
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - View source problem
Anyone know why I can't right click on a web page and view source? I get the list box but when I click on view source nothing happens. The box just goes away.
Sponsored Links
You might need to run a repair on the browser, or re-download the browser components.
If you have upgraded the browser, you can usually force a repair on the installation by attempting to remove the browser in Add/Remove Programs. Reinstall all components, even the ones that do not appear to need upgrading.
If that doesn't fix the problem, and you haven't upgraded, then check out Windows Update and install the latest version.
If you are running Netscape, reinstall the program, and hope for the best!
Toejam31
<font color=red>My Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new"><font color=green>Toejam31's Tantalizing Tantric Toy</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
____________________________________________________________
<font color=purple>"Procrastination on your part does not constitute an emergency on my part."</font color=purple>
Reply to Toejam31
I have the latest version of ie from windows update. It was a very slow download for some reason and crashed on install. Had to shut down. But went back to update and everything reinstalled and seemed ok. Had no reason to view source since. Don't know how long it has not been working.
Even weirder view source started working again for a little bit and then stoped.
I may be able to attempt to uninstall ie-6 and reinstall ie-5 from my WinME disk. Then go update it again. Think?
Reply to ppnl
I guess it couldn't hurt. You just never know what to think when WinME starts acting weird.
If you want the full download for I.E. 6, instead of fooling around with Windows Update, go <A HREF="http://www.tassie.net.au/news/010829-ie6.shtml" target="_new">here</A>.
Toejam31
Reply to Toejam31
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > View source problem
There are 1040 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
