Archived from groups: alt.audio.equipment,rec.audio.tech (More info?)
Hi all
Im hoping you can help me. I have an old amplifier with DIN inputs for tape,
phono and radio tuner only. I was wondering if it was possible to connect a cd
deck to this by plugging it into either the tape/phono/tuner input. will this
work, it'd be handy to know before shelling out for a cd deck!
thanks very much if you can help
jim
On 26 Dec 2004 16:29:17 -0800, jimsmithis@gmail.com (jim) wrote:
>Hi all
You can use either the tape or tuner inputs, not the phono. All you
need is the cable with the appropriate connectors on each end.
>Hi all
>deck to this by plugging it into either the tape/phono/tuner input. <snip>
Line level is line level. Only thing about using a tape input to a
receiver is you'll lose the ability to tape CDs, but it sounds like
you don't even have tape anyway. Phono inputs are NOT line level and
are RIAA equalized.
In <19f4b8d0.0412261629.2c3ed9f7@posting.google.com>, on 12/26/04
at 04:29 PM, jimsmithis@gmail.com (jim) said:
>Hi all
>tape, phono and radio tuner only. I was wondering if it was possible
>to connect a cd deck to this by plugging it into either the
>tape/phono/tuner input. will this work, it'd be handy to know before
>shelling out for a cd deck! thanks very much if you can help
>jim
Generally, on consumer gear, there are only three types of inputs:
Phono, Mic (microphone), and Line level. "Line level" is a generic term
for devices such as tape decks, VCR's, tuners, computers, etc.
(everything except Phono or Mic)
In your case either tape or tuner is appropriate for the CD player.
Note, however, that CD players generally put out a whopping signal
(about 2.0V) that may overload some older European DIN inputs that were
expecting something on the order of 0.1V. If this is your situation,
you may have enough range on your volume control do deal with the
situation, but the CD player may be very loud compared to the other
devices. In a few cases there will be obvious distortion and you'll
have to reduce the CD's output (some have output level controls) or
install an "attenuator" in the signal wire between the CD player and
your device.
spam: uce@ftc.gov
wordgame:123(abc):<14 9 20 5 2 9 18 4 at 22 15 9 3 5 14 5 20 dot 3 15
13> (Barry Mann)
[sorry about the puzzle, spammers are ruining my mailbox]
If a cassette deck or tuner with line level outputs on phono
connectors interfaces OK with the tape and tuner inputs, so will a CD
player. But you may have the older type DIN input which expects a
quite different electrical source. Either way, the phono input is a
no-no.
