I was looking for flat LAN cables so it would go under my door to the router located in another room. When I search for "flat ethernet cables" on Amazon, I get a bunch of results on "snagless" ethernet cables.
http://www.amazon.co.uk/gp/product/...&pf_rd_t=101&pf_rd_p=467128533&pf_rd_i=468294
This is slightly cheaper than flat cables and it's from Belkin.
Do the 2 terms mean the same thing (ie. flat/thin)?
