Feel the Love & Check Our Lists Twice
Archived from groups: rec.audio.tech (More info?)
http://cgi.ebay.com/ws/eBayISAPI.d [...] RK:MESE:IT Floorstanding Main Configuration for Full Range Sound MDF Wood Construction To Reduce Cabinet Resonance Vertically and Horizontally Internally Braced Cabinets Ferro-fluid Cooled Mylar Dome Tweeter For Longer Life Butyl Rubber Surrounds For Increased Durability and Performance High Excursion Side-firing 8" Subwoofer Binding Post Terminals for Optimum Conductivity Center Channel Magnetically Shielded Tuned Rear Bass Port for Controlled Low Frequency Response FRONT SPEAKERS: Dimensions: 33" x 8.3" x 9.8": H/W/D Weight: 27LBS EACH SPEAKER CENTER SPEAKER Dimensions: 6" X 16.2" X 6.6" H/W/D Weight: 9 LBS SURROUND SOUND SPEAKERS: Dimensions: 9.7" X 6" X 6.6" H/W/D Weight: 5 1/2 lbs EACH SPEAKER
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
