M-Audio 2496 problem (possibly)
Last response: in Home Audio
Archived from groups: rec.audio.tech,rec.audio.pro (More info?)
I've been using Audition + the 2496 to do some vinyl-to-digital
transfers, and noticed that the left channel level usually seemed a
bit lower than the right, no matter what LP I was transferring.
I attributed this to some problem with my turntable setup, and
set about checking and adjusting cartridge overhang,
angle, tracking force etc -- which only reminded me why I was so
happy to switch to CD years ago. Anyway, having done that the problem
was still there, so I set about chekcing other components of the chain.
I was very surprised to find that, with all cables disconnected
from the soundcard, if I recorded as normal (i.e., Audition set to
record from the 2496's analog L/R inputs), the ambient 'noise'
tus captured *also* shows the left channel level to be ~1 dB lower
on average than right. It's also quite visible by watchign the
static and dynamic peak indicators while recording -- the peak always
tends to end up about 1 dB higher for the right than the left.
This is not the case if I select the 2496 S/PDIF
input as source, btw -- there the noise floor is not only lower,
as expected, but the peak and everage values for L and R do not differ
very much at all, nor do they favor one channel over another.
How and where else might I check for the source of this difference,
before assuming that there's a problem with the card? It's installed
in a bog-standard Dell PC running WinXP Home. My other question would
be, what am I actually recording when there's nothing connected to
the inputs? Is it the 'sound' of the card, the sound of the PC, or
some combination?
some combination?
More about : audio 2496 problem possibly
"Steven Sullivan" wrote ...
> chain.
Have you tried feeding a MONO signal into both inputs (using a
Y-adapter, for example)? It seems possible that the analog gain
in your 2496 is out of balance. I'd guess that 1dB unbalance exeeds
the manufacturer's spec. Can you return it? Or you could just
compensate somewhere else, either hardware (like trimming the
RIAA preamp?), or software (do you do any processing, cleanup,
normalization, etc.?)
I am surprised that you see ANYTHING (noise or otherwise)
with thet SPDIF input. If there are no bits going in, there is nothing
to interperet as audio (even noise).
I would feed a mono signal into both inputs with a Y-adapter to
prove that the two channels are behaving differently with exactly
the same input signal.
> It's installed in a bog-standard Dell PC running WinXP Home.
> My other question would be, what am I actually recording when
> there's nothing connected to the inputs? Is it the 'sound' of the
> card,
> the sound of the PC, or some combination?
It is likely the sound of the analog parts of the card (before and
including the A/D converter). Might also be picking up noise
from inside the computer case (depending on many things).
OTOH, with digital input (SPDIF), I'd expect to see NOTHING
(pure, digital-zero "silence") unless you have some SPDIF source
connnected.
> chain.
> card,
connnected.
I should add that I also tried removing and re-inserting it
the soundcard from its expansion slot, on the theory that there
was some crud on the contacts -- but that didn't change
anything. I haven't tried using a differend slot.
In rec.audio.tech and rec.audio.pro, on Thu, 30 Dec 2004 11:49:07
>> chain.
What components are those? Specifically, what cartridge are you
using, and what are you using for the RIAA phono preamp? Many
cartridges have a spec for output match between channels, and it can
be 0.5 dB or so, depending on model.
>RIAA preamp?),
Also, similarly feed a mono signal into the RIAA preamp with its
outputs connected to the soundcard normally, and see what the
imbalance is (might as well try this at several frequencies, to check
if both channels have the same EQ). If the imbalance is the same as it
is going directly into the soundcard, then the soundcard is the
problem. If not, then the RIAA preamp is a problem (but perhaps not
the only problem).
http://mindspring.com/~benbradley
>> chain.
>RIAA preamp?),
the only problem).
Related ressources
- M-Audio 2496 Right Channel problems - Forum
- M-Audio Audiophile 2496 w/ SiS-based motherboard - Forum
- M-Audio : Audiphile 2496 or Delta-44 - Forum
- How well does " M-Audio Audiophile 2496 " work with (EASport.. - Forum
- M-Audio 2496 : Win 7, or Xp? - Forum
Thu, 30 Dec 2004 19:23:06 +0000 (UTC), Steven Sullivan
<ssully@panix.com> pisze:
Did you check settings on M-Audio mixer? You can have line-in out of
balans. I think this mixer works in digital domain, so it can
attenuate ADC noise level.
Pozdrowienia
Andrzej Popowski
Pozdrowienia
Andrzej Popowski
Yes, I made sure all the mixer faders were really at 0.0 dB when I first
noticed the problem.
-S
If you're a nut and knock on enough doors, eventually someone will open one,
look at you and say, Messiah, we have waited for your arrival.
-S
> some combination?
See what happens when you record a mono signal, as suggested before.
Also, try swapping the channels, connect the left to the right input and
vice versa. If everything is equal, you should now see the left side 1
db higher than the right. If not, then I would have to conclude the the
M-Audio card is suspect. Not in a major way, though. Allot of my analog
stereo recording tends to be off by 1-1.5 db, but when I do a test
recording in mono my left and right levels are perfectly even.
CD
CD
> some combination?
CD
CD
> > some combination?
> CD
If I didn't make it clear -- I see this imbalance even when there's
*nothing connected to the soundcard inputs*. So swapping channels should
make no difference.
-S If you're a nut and knock on enough doors, eventually someone will open
one, look at you and say, Messiah, we have waited for your arrival.
> > some combination?
> CD
make no difference.
In article <cr7kiq$fkk$1@reader1.panix.com> ssully@panix.com writes:
> make no difference.
You made it clear - there's 1 dB difference between channels.
There are a number of freeware programs out there which will create a
WAV file of a single frequency. In fact I think that Audition does
this. Make a 1 kHz file about five minutes long, burn it on a CD, and
use your CD player as a tone generator. That will give you a
calibration signal. Connect it to your sound card inputs and read the
meters. If one is 1 dB off from the other, open up the control panel
and adjust the gain so that the channels are balanced. That's all
there is to it.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
> make no difference.
there is to it.
2 Jan 2005 10:05:27 -0500, mrivers@d-and-d.com (Mike Rivers) pisze:
>there is to it.
OK, that is practical solution, but IMHO there is an error in hardware
or in software setup, that we are unable to trace down.
1dB is about 12% difference of voltage gain. Analog input of DAP2496
consist of 3 opamp 5532 and ADC chip AKM4528VF. I would not expect
more than 1% gain error from that kind of setup, unless something is
wrong.
To Steven: try this software to test your card performance:
http://audio.rightmark.org/downloads/rmaa54.exe
All you need is to connect a wire from line-out to line-in and run
RMAA. It will measure frequency response, dynamic range , distortion
and crosstalk of your card. Check please if there are no other
differences between channels.
Pozdrowienia
Andrzej Popowski
>there is to it.
wrong.
Pozdrowienia
Andrzej Popowski
> > make no difference.
> there is to it.
No need to -- I did the y-adapter mono test instead, using an audio test
CD as source. Used the pink noise L/R and spot frequency tracks as tests.
And what do you know -- the L and R channel difference
disappeared (channel difference was on the order of 0.05 dB at most).
It came back to ~1.0 dB when the cables were disconnected. So it looks like
there is a channel difference when there's nothing connected, and the
channel difference I saw when I was transferring vinyl was either the LPs,
the TT or the RIAA preamp.
As such I'm not going to fuss about it any longer, I'll just compensate
in the digital realm if need be. Thanks to everyone for their input.
> > make no difference.
> there is to it.
> >there is to it.
> wrong.
HAving jsut said I won't fuss with this matter any more, I *will* however
try this. ;> Thanks.
-S
> >there is to it.
> wrong.
-S
results of 32bit/48kHz (my dstandard trasner parameters)loopback test
Frequency response (from 40 Hz to 15 kHz), dB: +0.02, -0.08 Excellent
Noise level, dB (A): -98.6 Excellent
Dynamic range, dB (A): 93.0 Very good
THD, %: 0.0047 Very good
IMD, %: 0.012 Very good
Stereo crosstalk, dB: -101.3 Excellent
IMD at 10 kHz, %: 0.011 Very good
So it looks again like the card is fine by these measures.
-S
-S
and here are individual L/R breakdowns.
Are the IMD and THD discrepancies significant?
Noise level Left Right
RMS power, dB: -94.8 -94.7
RMS power (A-weighted), dB: -98.6 -98.4
Peak level, dB FS: -79.2 -77.0
DC offset, %: -0.00 -0.00
Dynamic range
Dynamic range, dB: +91.9 +91.9
Dynamic range (A-weighted), dB: +93.1 +93.0
THD + Noise (at -3 dB FS)
THD, %: 0.1226 0.0047
THD + Noise, %: 0.7154 0.0110
THD + Noise (A-weighted), %: 0.6257 0.0090
Intermodulation distortion
IMD + Noise, %: 0.5387 0.0118
IMD + Noise (A-weighted), %: 0.4722 0.0099
Crosstalk
Parameter L <- R L -> R
Crosstalk at 100 Hz, dB: -100 -102
Crosstalk at 1 kHz, dB: -100 -99
Crosstalk at 10 kHz, dB: -95 -95
IMD (swept tones)
IMD + Noise at 5 kHz, %: 0.0175 0.0116
IMD + Noise at 10 kHz, %: 0.0381 0.0112
IMD + Noise at 15 kHz, %: 0.0891 0.0112
-S
Dynamic range
Crosstalk
IMD (swept tones)
-S
In article <craagd$em6$1@reader1.panix.com> ssully@panix.com writes:
So when you disconnect the cables, what are you testing that you could
see the 1 dB difference? Have you tried playing a mono record into it?
Or putting your test tone into the phono preamp with it connected to
the sound card? (be sure to knock the level down 40 dB or so!)
> . . . . and the
That's what it sounds like to me. But I don't understand the part
about "with nothing connected." Oh, well, as long as you're happy.
> . . . . and the
Mon, 3 Jan 2005 02:50:54 +0000 (UTC), Steven Sullivan
There is something wrong with left channel. Right is OK, these are
values one can expect form DAP2496, but values for left channel are
comparable to low cost audio, like onboard AC chip.
You can cross-connect wires, to check if distortions come from input
or from output part of card. In either case I think your card is out
of order - it works, but it does not meet required performance.
Pozdrowienia
Andrzej Popowski
Pozdrowienia
Andrzej Popowski
> Dynamic range
> Crosstalk
> IMD (swept tones)
Your soundcard is definitely out of whack somehow. Look how your
distoriton at high frequencies is 3 to 8 times higher on the left
channel as it is on the right.
CD
> Dynamic range
> Crosstalk
> IMD (swept tones)
CD
OK, that accords with my observation that the left channel was wonky.
Good to know, thanks! By cross connect do you mean, R out to L in and
L out to R in?
-S
L out to R in?
-S
Beats me, but *something* is registering on the recording software level meters,
down in the region of -85 or so dB, when I monitor the analog input
path. Have you ever tried this with your card?
I don't have any mono records, but as noted above I did split the
output of one channel of a stereo CD, into two with a Y-cable,
at the card input, and that gave me even levels on both channels.
That seemed to indicate that the problem was really in the LP chain.
But it now also seems that there's a real problem in the left channel
of the card (see my mightmark IMD results).
> > . . . . and the
'with nothing connected' mean: no cables connected to the soundcard.
Then set Audition (for example) to 'record' from the analog inputs.
Which I presumed meant just recording the card's analog path
while it's 'idling' -- not responding to actual input. Or maybe it's recording
'ambient noise' of some sort. Perhaps Arny or someone can say what's
actually going on in 'nothing connected' configuration.
Intersteingly , the noise levels I see from 'nothing connected' are
higher than for a loopback test, where cables connect the card analog
output to its analog input during 'record'.
-S
> > . . . . and the
-S
Archived from groups: rec.audio.pro (More info?)
On Mon, 3 Jan 2005 21:17:43 +0000 (UTC), Steven Sullivan
1 dB matching in a phono cartridge would be excellent
performance in the real world. Not to worry.
>Interestingly , the noise levels I see from 'nothing connected' are
Open-input noise tests are pretty much meaningless. Shorting
plugs are good enough for telling you something useful.
Good fortune,
Chris Hornbeck
"They'd meet at the Tout Va Bien, a cafe just off the highway."
-JLG, _Bande a part_, 1964
Good fortune,
Chris Hornbeck
Mon, 3 Jan 2005 21:05:48 +0000 (UTC), Steven Sullivan
>L out to R in?
Yes. If THD results remain the same, then it means that input circuit
is responsible for distortion.
Pozdrowienia
Andrzej Popowski
>L out to R in?
Pozdrowienia
Andrzej Popowski
In article <crccpn$8uj$1@reader1.panix.com> ssully@panix.com writes:
Well, with the input open-circuited, it's indeed responding to ambient
noise (which may be generated internal to the sound card). I would
expect something like that, and I wouldn't necessarily expect it to be
identical on both channels. If you want to make a true "nothing going
in" test, make up a couple of shorting plugs - an RCA plug with a
jumper wire connected betwen the tip and shield. Plug those in and
then look at the quiescent noise.
It could be that one channel is a tad noisier than the other, and
that's why the THD+M figure is higher. THD isn't just harmonics of the
input signal, it's everything but the input signal, and that includes
self-noise and stray noise pickup.
That's not surprising either since with "nothing connected" there's no
shielding on the inputs.
> >L out to R in?
It has occurred to me that I might be doing something wrong in setup --
I have these choices when selecting output to the analog jacks
WavOut
Monitor Mixer
S/PDIF
S/PDIF reversed channels
H/W 1/2 In (analog in)
I've been using WavOut because the other inputs produced
warnings of 'level too low' in Rightmark.
Is that correct? Selecting H/W 1/2 In doesn't produce
usable results (due to low levels), and the test aborts.
Only WavOut allows Rightmark to works to completion.
Anyway, I *also* found that in the *Windows* volume control panel,
the fader for WAV/MP3 was set to about halfway. I adjusted this
to full output. I don't know if this was the reason for the
previous results, but when I reran the Rightmark test
(with normal L/R analog loopback connection, input set to
WavOut as before), distortion levels looked much better
for the left channel than before.
RMS power, dB: -94.8 -94.6
RMS power (A-weighted), dB: -98.7 -98.3
Peak level, dB FS: -79.2 -79.2
DC offset, %: 0 0
Dynamic range, dB: 92.1 91.9
Dynamic range (A-weighted), dB: 93.2 93.1
DC offset, %: 0 0
THD, %: 0.0048 0.0047
THD + Noise, %: 0.0113 0.0111
THD + Noise (A-weighted), %: 0.0091 0.0091
IMD + Noise, %: 0.0117 0.0117
IMD + Noise (A-weighted), %: 0.0099 0.01
Crosstalk at 100 Hz, dB: -105 -102
Crosstalk at 1 kHz, dB: -100 -100
IMD + Noise at 5 kHz, %: 0.0113 0.0114
IMD + Noise at 10 kHz, %: 0.011 0.0112
IMD + Noise at 15 kHz, %: 0.0112 0.0112
rerunnign the test with crossed connections,
produces essentially the same result (except for
bad crosstalk, as expected)
RMS power, dB: -94.7 -94.6
RMS power (A-weighted), dB: -98.6 -98.3
Peak level, dB FS: -77 -77
DC offset, %: 0 0
DC offset, %: 0 0
THD, %: 0.0049 0.0047
THD + Noise, %: 0.0112 0.0112
Crosstalk at 100 Hz, dB: -5 -5
Crosstalk at 1 kHz, dB: -5 -5
Crosstalk at 10 kHz, dB: -5 -5
IMD + Noise at 5 kHz, %: 0.0115 0.0114
IMD + Noise at 10 kHz, %: 0.0111 0.0113
IMD + Noise at 15 kHz, %: 0.0111 0.0111
so all looks to be well after all...?
> >L out to R in?
WavOut
Monitor Mixer
S/PDIF
DC offset, %: 0 0
DC offset, %: 0 0
DC offset, %: 0 0
DC offset, %: 0 0
Tue, 4 Jan 2005 13:00:27 +0000 (UTC), Steven Sullivan
Looks like you solved the problem :-)
Pozdrowienia
Andrzej Popowski
Pozdrowienia
Andrzej Popowski
I wish it was always that easy ;>
Thanks to everyone for their patience and assistance.
-S
-S
Related ressources:
- ForumWill an USB aound adpter conflict with my M-Audio Delta 2496 ?
- ForumProblems with M-Audio Audiophile 2496
- ForumMore On M-Audio MicroTrack 24/96 : S/PDIF, Mono, Playback
- ForumM-Audio Delta 2496 & Cool Edit question
- ForumMaudio Audiophile 2496 for DAW HELP
- ForumM-AUDIO Audiophile 2496 help
- ForumHelp:bought Audiophile 2496 ;sounds just like my SB Live!
- ForumM-audio audiophile 2496 vs Asus Xonar Essence STX, best stereosound
- Forum- Echo / M-Audio / Lynx comparisons?
- ForumM-Audio Sound Card?
- ForumAnybody who has Audigy + M-Audio Audiophile in same PC?! C..
- ForumM-Audio 's response to 48v phantom power bug
- ForumLexicon Omega vs. M-Audio FWIRE 410
- ForumSP2500's or Another Subwoofer?
- ForumComparing two USB audio devices (M-Audio MobilePre & Alesi..
- More resources
Read discussions in other Home Audio categories
