Tom's Hardware > Forum > Audio > Audio Technology > Ripping DVD-Audio at 24-bit 96MHz?
Forum Audio : Audio Technology - Ripping DVD-Audio at 24-bit 96MHz?
Archived from groups: rec.audio.tech (More info?)
I'm trying to rip the stereo song tracks from my DVD-Audio of Fleetwood
Mac's "Rumours". All attempts to do so yield only 16-bit AC3 files
(frequency unknown). That does me no good; I want 24-bit, 96Mhz files I
can later convert to 24-bit (and at least 48MHz) .wav files that I can
burn to CD (or DVD, if necessary).
I have an M-Delta 2496 card, Windows XP (with Windows Media Encoder
SDK), Soundforge 7.0, a freeware DVD ripping program.
(I should also mention that I can't seem to get the 2496 card to rip or
play anything other than 16-bit 44MHz audio files; the Windows XP
Soundmax internal card seems to take precedent over the 2496).
Shnaggletooth
Sponsored Links
<shnaggletooth@yahoo.com> skrev i en meddelelse
news:1104911008.952764.285100@f14g2000cwb.googlegroups.com...
> Shnaggletooth
Damn !.
I wanna get me one of them 44MHz cards tooo. My Delta 2496 card only goes to
96kHz.
/Jakob
Reply to Anonymous
- 0 +
<shnaggletooth@yahoo.com> wrote in message
> Shnaggletooth
The Creative Audigy 2 records up to 96khz sampling rate and 24bits if that's
what you want. You have quoted figures of 96Mhz and 44Mhz which do not
exist.
Paul
Reply to Paul
<shnaggletooth@yahoo.com> wrote ...
> Fleetwood
> I
> or
> Shnaggletooth
If by "ripping" you literally mean recovering the digital bitstream
from the original, then you get whatever they encoded it for.
"Ripping" to a higher sample rate or word-length is undefined.
Reply to Anonymous
Richard Crowley wrote:
snip
I'm trying to rip the high resolution stereo stream that's in the
DVD-Audio (because I don't have a DVD-Audio player), which should be
24-bit, 192Khz. Those I think are the AOM files in the audio folder of
the DVD. The most I can do so far is rip the 16-bit 48Khz Dolby Digital
AC3 stream from the VOB files in the video folder.
Shnaggletooth
Reply to Anonymous
- 0 +
news:1104941217.856713.14150@c13g2000cwb.googlegroups.com...
> snip
Have you looked at the figures on http://www.amtechdisc.com/dvdspecs.htm
Might help.
Paul
Reply to Paul
- 0 +
>snip
As I understand it the DVD-Audio stream is copy protected. For
compatibilty most of them have a Dolby Digital stream which can be
played on standard DVD players, and extracted with standard DVD tools.
I don't know of any tools that can extract the high resolution stream.
Bill
Reply to bill
Simply because that is what the software is designed to do. AFAIK no
software yet exists for ripping the high res layer. I'll bet people are
working on it though.
MrT.
Reply to Anonymous
"Richard Crowley" <rcrowley7@xprt.net> wrote in message
news:10to05jkt14v732@corp.supernews.com...
>> Shnaggletooth
DVD Audio Ripper lets you select the DVD's AC3 or PCM-2 audio stream.
geoff
Reply to Anonymous
"Geoff Wood" <geoff@nospam-paf.co.nz> wrote in message undefined.
> geoff
DVD AUdio Ripper being for ripping audio tracks of video DVDs, of course,
not of DVD-A's
geoff
Reply to Anonymous
be
of
Digital
are
> MrT.
Check out "DVD Audio Extractor"
You can extract 16 bit, 24 bit, 5.1... you name it. Works great.
DVD Audio Extractor home page:
http://www.castudio.org/dvdaudioextractor/
Reply to Anonymous
- 0 +
>be
>of
>Digital
>are
>> MrT.
Well its web site says -
Q7: Can DVD Audio Extractor be used to extract music from DVD-Audio
discs?
Not yet. This is a known limit. DVD Audio Extractor currently only
support audios in DVD-Video discs, i.e., it reads VOB files under
VIDEO_TS directory. DVD-Audio discs store audio tracks under AUDIO_TS
directory and use different formats with DVD-Video.
Suggestion: Many DVD-Audio discs also come with an DVD-Video zone for
compatibility with DVD-Video players. In that case, you can extract
audios from them as normal DVD-Video discs.
Which seems to be saying that it will not extract high res audio from
DVD-A discs.
Bill
Reply to bill
> be
> of
> Digital
> are
> > MrT.
It won't extract DVD-Audio, at any bitrate of format, though.
-S
If you're a nut and knock on enough doors, eventually someone will open one,
look at you and say, Messiah, we have waited for your arrival.
Reply to Anonymous
"enaille" <enaille@hotmail.com> wrote in message
news:1105474020.800412.196170@c13g2000cwb.googlegroups.com...
> >are working on it though.
> > MrT.
But as I said, it won't do DVD ***AUDIO*** disks.
Someone must be working on the problem though. It's only a copyright issue
MrT.
Reply to Anonymous
Either - and preferably - disable the soundmax in the bios or set the AP
to be preferred device and ask xp to use only preferred devices. You can
also create a hardware profile that excludes the soundmax. Strange btw.
that you shold have that problem, the on board crystal card on this 300
Mhz Optiplex does 96-24 ....
> 24 bits if that's what you want.
<caveat, not absolutely sincere>
It isn't, he obviously needs the hitherto undocumented capabilities of
the AP, and I am positively convinced that its superior sound quality is
due to the higher internal sampling rate. The Audiophile cards are
simply 1000 times oversampling and thus also 1000 times better .... O;-)
..... than the card you suggest.
</caveat, not absolutely sincere>
> exist.
Oh, they exist, and cards that sample that fast - or something up there
in the Megahertz range are very good at filling up harddisks fast, as I
recall hearsay the Niels Bohr Institute have some hardware a la that in
their basement.
> Paul
Peter Larsen
* My site is at: http://www.muyiovatki.dk *
Reply to Anonymous
There are 1235 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
