I just bought a nice 15" driver for musical instrument use. It seems so
much more convenient to mount the driver on the front of the baffle, to
avoid having a removable lid. Yet drivers always have the gasket on the
front. What gives?
so
to
the
> front. What gives?
What gives is that the "gasket" is not there to force you to
mount the speaker from the rear, it's there as part of the
assembly procedure for glueing the surround edge to the basket.
It's also there to prevent damage to the surround during
manufacturing, packing, shipping and storage by separating
the surround from whatever surface it's going to be resting
against.
Generally, on a lot of drivers, this "gasket" would make a very
poor gasket, often being made with fairly thick, dense die-cut
cardboard, which is not very pliable. Those qualities which make
it a lousy gasket make it a good means of securing the surround
until the adhesive properly sets and further strengthens that
joint.
Basically, mount it any way you want and ignore what you think
the gasket is telling you. Who's in charge of this project, you
or the gasket? :-)
<dpierce@cartchunk.org> wrote in message
news:1105411900.001415.175940@c13g2000cwb.googlegroups.com...
> against.
> joint.
Yes that's about all it's good for, personally I think they could use a
better method though if they wanted. It seems to be just tradition as far as
I can see, because some drivers have no front "gasket" and are none the
worse for it.
> or the gasket? :-)
Very good advice Dick, but I still find it amazing how few drivers have a
good mounting surface at the rear. It's difficult enough with most stamped
chassis types, but even some cast chassis could be better designed IMO.
>front. What gives?
Make sure it WILL rear-mount. There may not be a suitable flat
flange.
