I don't think the IDE LED has ever worked on by ASUS A7V MoBo, but now, I'm sure it doesn't. I plugged it in at the exact spot described in the booklet (the guys who built my computer when I bought it had plugged it somewhere else...), but nothing happens. Does anyone know the real place for this LED? (explaining should be fun...)
Sponsored Links
If it doesn't work at that jumper in one direction, flip it around.
Bryan
<font color=red><A HREF="http://www.btvillarin.com" target="_new">btvillarin.com</A> - My Windows XP-based Website</font color=red>
Reply to btvillarin
- 0 +
In the manual page 14 bottom right of the motherboard layout picture, above the Panel it say IDELED. That's it, if doesn't work then what dude said, flip the plug around and see (can flip it while system runing). Led's work only one way.
<font color=red>We born naked and screaming, then it gets worse.</font color=red>
Reply to AndrewT
Thanks for the elaboration... :wink:
Reply to btvillarin
I tried that exact spot, and reversed too, to no avail. I had tried that with the old case, with no more success. Unless of course the switching actually fried the leds...
Reply to Anonymous
- 0 +
take the power led, put a small wire into one end, slide the other over the led connector, touch the wire to the other ideled connector and see if it light up when using hard drive or cd-rom,turn it around if still doesn't work. if nothing help then it could be a screwed connector. No biggie, just one less light, only visual loss (I don't even look at the led).
the wire needed because the power led connector 1 bigger than the drive led connector
if I'm not clear then let me know, will take pictures. :)
Reply to AndrewT
Tom's Hardware > Forum > CPU & Components > Other Components > Led problem now...
There are 980 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
