G
Guest
Guest
Hi Guys,
would it be reasonable/safe/advisable to do the following:
Create a 5 gig partition on my 20gig drive and backup essential data to it.
Format my main partition and re-install windows2000
reclaim my backed up data by merging the partition after installation is complete.
Any comments? I need to do this because I want to repair some oddities caused by a bios installation. My only worry would be with assigned drive letters and the like, if any partitioning guru can help I would be grateful. Thanks folks!
