G
Guest
Guest
I've been getting BSODs for months now, and I try to ignore them, thinking in the back of my head I'll finally get an SSD and reinstall Windows to eliminate the problem. Anyways, just recently I was sobbing over my weak GPU (6950 2GB) and was going to check my PC ratings in the W.E.I. and noticed it needed to be refreshed. I could not refresh it without getting a BSOD. This happened 3 times, so I'm asking for help.
As you can see, the 3 from 4/1/2012 are the crashes from trying to refresh W.E.I.
All the others are just random ones I get for no reason known to me. :/
The last picture is from a while ago so I just added it in.
