Tom's Hardware > Forum > Audio > Audio Technology > sound card mic / output socket proximity (!)
Forum Audio : Audio Technology - sound card mic / output socket proximity (!)
Archived from groups: rec.audio.tech (More info?)
Hmmm... Having bought decent leads for my mic and audio output to an
amp, I can't plug them both in at the same time - the two sockets are
next to each other (and close together) on my soundblaster sound card.
My motherboard has a built in sound card which might be a solution for
having them plugged in seperately... but how do I run one sound card
for my output (to amp and speakers) and the other (the one on the
mother board) for my mic input? Any ideas anyone?
Sponsored Links
"kooppp" [in the UK] wrote ...
> audio output to an amp, I can't plug them both in at the
> same time - the two sockets are next to each other (and
I would take the cables back and buy some sensible ones.
If you pay any more than 5 pounds for such a cable, you
are buying sizzle and not steak. There is no mechanical
reason for the connectors to be so big. I'd suspect that the
marketing gerbs wanted something impressive to justify
the premium price.
If they are moulded plastic, you could try carving off some
of the excess girth. But that is risky as you don't know what
is inside and it would destroy any resale value.
> a solution for having them plugged in seperately... but how
> do I run one sound card for my output (to amp and speakers)
> and the other (the one on the mother board) for my mic input?
> Any ideas anyone?
Likely not practical.
Reply to Anonymous
On 20 Jan 2005 00:12:27 -0800, mike@kooppp.freeserve.co.uk (kooppp)
Does "decent" mean "overpriced, with gigantic gold-plated
connectors"? :-)
"Decent" should mean "suitable for the purpose". Take them back.
The mic input on Soundblaster and other domestic sound cards has no
pretense to quality. Use an external mixer or preamp (which will
accept a quality mic) into Line In.
I assume you're looking for audio quality. Premium cables aren't the
answer, but all credit for trying :-)
Reply to Anonymous
There are 1359 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
