Tom's Hardware > Forum > Audio > Audio Technology > Running cable through Sherwood RD-6108?
Forum Audio : Audio Technology - Running cable through Sherwood RD-6108?
Archived from groups: rec.audio.tech (More info?)
My receiver is a Sherwood RD-6108. I like it well enough but am
confused as to how to run my incoming cable into it so as to hear tv
programing over the stereo. Right now I just have the cable running
directly into the tv and sound coming over the tv speakers. Is there
any way to remedy this?
Thanks.
Sponsored Links
In article <1106697141.866989.255060@c13g2000cwb.googlegroups.com>,
> Thanks.
I went through this as well. You have two choices as far as I can see:
1) Get a TV with audio out (I chose this option)
2) Use a VCR as a tuner and bring the audio from the VCR into the
Sherwood. This works but requires a separate remote and I never use a
VCR anymore as I usually watch DVDs.
It seems to me that a true HT receiver should accept cable and be able
to act as a central distribution point for video and audio signals
alike. There's already an FM tuner in there, so how hard would it be to
have a cable tuner as well?
HTH
Edwin
Reply to Anonymous
There are 1496 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Latest best answer
Speaker recommendation
By astrallite, 2 days ago:
Try this: Sherwood 5.1 receiver ($172 shipped). http://www.amazon.com/Sherwood-RD6 [...] 05&sr=8-10 Energy Take 5s ($199) http://www.newegg.com/Product/Prod [...] 20take%205 Dayton Sub 80 ($75) http://www.parts-express.com/pe/sh [...] er=300-631 This should come out to $450. As far as Bose goes, unless you are talking about the x01 series from the 70s (which were pretty good back then), their modern speakers are just clock radios designed for decor-conscious older people who need invisible speakers. Acoustically they are no better than your typical PC satellite speakers (I'm being generous here, they are probably worse than high end PC speakers); they really are nothing more than a couple of thin plastic cans. The satellites replacement drivers that you can request from Bose cost $2 (low quality untreated paper drivers) and the satellites themselves are built with thin cheap plastic enclosures. That should give you an idea of build quality...it's basically a product with 95% markup. I doubt their $1000 acoustimass systems cost more than $50 to manufacture. To give you an idea what a value product is, in my bedroom I have a pair of Ascend Sierra 1 bookshelf speakers that go for $800/pair. The tweeters that Ascend purchase from SEAs of Norway cost $200/each, or $400/pair. Include the cost of diamond drill bits for industrial cutting tools needed to cut through 3/4" solid bamboo enclosures, the long-throw injection-molded poly midrange/woofers, and a high gloss piano black automotive finish and you are talking about $600 manufacturing costs. After shipping and handling, I doubt they make more than 25%, a fraction of Bose's margins. It's called name brand markup. That said, it's your money, if you want to buy it, it's your prerogative. And to your room, it's about 11x11 as I understand it? It's not THAT small. I'm running a pair of bookshelf speakers that run 60lbs on 80lbs of solid metal stands and they work fantastic in a 166sq foot office (only slightly bigger than your room).
Related Content
