Power Supply Advice
Forum CPU & Components : Other Components - Power Supply Advice
I just built a machine (Athlon 1700) and the power supply with the case is pretty noisy. The case fans are pretty quiet, but that power supply is getting on my nerves. I want at least a 350 watt; any suggestions for very quiet power supplies? Or are they all noisy?
Whether you think you can, or think you can't, you're probably right!
Sponsored Links
Enermax, they're so quiet you will think it's off
<font color=red>We born naked and screaming, then it gets worse.</font color=red>
Reply to AndrewT
- 0 +
I agree. Enermax PSUs are very quiet.
Reply to upec
- 0 +
I have an Enermax ( EG651P-VE) and it is very quiet. I trust and recommend Enermax.
:smile: <b><font color=blue> I took an I.Q. test today...It came back negative.</font color=blue></b> :lol:
Reply to OldBear
- 0 +
Another vote for Enermax!
Rob
Please visit <b><A HREF="http://www.ncix.com/canada/about.php?affiliateid=319048" target="_new">http://www.ncix.com/canada/about.php?affiliateid=319048</A></b>
Reply to Arrow
Thanks everyone for the advice. I ended up buying an Enermax 350 watt, mainly based on the 'quiet' advice. I got it for $56, shipping included, so I will have a quiet machine in a few days! Again, thanks a amillion for the advice.
Reply to Anonymous
Why is my Enermax 550W so loud?
I can't think of a good signature so I'll use this one.
Reply to Black_Cat
- 0 +
No idea why, my 550 idle nice and quiet. Maybe the fan speed is temperature controled and your box run warmer than mine, no clue and I'm not going to open it to see till I have warranty on it. :)
Reply to AndrewT
- 0 +
My Enermax 550 is quiet. If that is your only exhaust from your case it will run
with both fans on high to get rid of the heat but even then it should not be loud.
Reply to OldBear
- 0 +
with enermax PSU's i read a lot about active and passive PFC. what is it exactly ?
thx
GzG
Nerun
Reply to Nerun
Tom's Hardware > Forum > CPU & Components > Other Components > Power Supply Advice
There are 1287 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
