Archived from groups: rec.audio.tech,microsoft.public.windows.mediacenter,rec.audio.opinion (More info?)
Hi,
I connected my Gateway 610X media center computer to my Harman Kardon
AVR315 (I have B&W CM4 speakers) via the digital optical audio using a
Toslink cable.
Well, whatever you're doing, it's NOT the cable. Digital is digital, if
you're hearing anything at all that sounds remotely like you expect it
to, then it's not the cable. A digital cable will not selectively drop
high or low frequencies.
> Toslink cable.
> I am getting the mid ranges and the trebles but I am not getting any
> bass. What do you think is the problem?
My guess would be that the Gateway * is directing the bass to the subwoofer
channel, but you don't have a subwoofer.
* it could also be the Harman Kardon, but the default setting is probably to
send the bass to both the subwoofer and the front speakers, and if you had
changed it you would know. But check page 17 and followings in its manual:
It seems to have the usual displays, showing the channels in
which it is receiving signals on the right side. So for instance,
if you are listening to stereo, you should see the "L" and "R"
displays lighted. If the Gateway is sending the bass to the
subwoofer channel, the "LFE" (Low-Frequency Effects) channel
should light up.
On the left side it seems to show the type of input it is seeing.
I am not sure what it will show if the Gateway is sending PCM
(nothing ?).
"nash123" <bulent74@gmail.com> wrote in message
news:1107323686.192135.278520@f14g2000cwb.googlegroups.com
> Toslink cable.
For openers, the Toslink cable isn't the cause of your problem. This kind of
digital interface either transmits nothing or everything.
Probably cause - how you have defined the speakers, in the setup feature of
the receiver. Your receiver has bass management features that control the
frequency ranges sent to various speakers in your system. This is why the
bass is not getting through - your receiver is adjusted to not send bass to
these speakers.
You should define the CM4s to the receiver's bass management for these
speakers as being "large" unless you have a really bodacious subwoofer.
Archived from groups: rec.audio.tech,rec.audio.opinion (More info?)
nash123 wrote:
> Hi,
> Toslink cable.
> http://support.gateway.com/s/PC/TV [...] 10nv.shtml >
> http://harmankardon.com/product_de [...] 35&sType=C >
> http://www.bwspeakers.com/index.cf [...] l%20CM%204 >
I'm willing to bet it's your Harman Kardon AV receiver. It's not broken,
just mis-configured. Since you're using BW CM4s then the Harmon should
be configured to run with stereo speakers only, no subwoofer, no 5.1 7.1
etc. With that configuration, all audio frequencies will go to the left
and right channels.
Hi again,
I should have mentioned in my first email but I had already set the
receiver to "surround off", just bare stereo output, with no subwoofer
or surround speakers. I also had selected "large" for the floor
speakers, so the signal should have included the bass to the speakers.
I agree with all that it is a receiver issue but I looked at all
options that I could tweak but did not help. I am hoping to find a CD
player with optical digital output so that I can try this again but I
just could not find one yet.
It is still a mystery to me.
Codifus wrote:
> nash123 wrote:
> > Hi,
Kardon
using a
> > Toslink cable.
http://support.gateway.com/s/PC/TV [...] 10nv.shtml > >
http://harmankardon.com/product_de [...] 35&sType=C > >
http://www.bwspeakers.com/index.cf [...] l%20CM%204 > >
any
broken,
should
7.1
left
> and right channels.
> CD
Sorry I just saw your posting - Like I said, I only have the floor
speakers configured on the AVR, no surround, no subwoofer etc. On
regular signals from my CD player (analog) the signal has all treble
mid and bass.
It is likely that this may be a Gateway issue too, since it has a built
in subwoofer. But when I hook up the Toslink, Gateway does not mute,
it also plays the song on the speakers. I would have thought only the
subwoofer would play since the rest goes to the BW4s, but no. The
setting on Windows is set for 2 speakers, it is not set for home
theater, so it is probably not Gateway either..
When I select optical input, it shows Optical 1 only. It does not have
anything to do with DVD or CD selection. So the screen shows
DVD/Optical 1 or CD/Optical 1, but it would still play. On the left
side, since I turn all surround off, nothing shows up. Also I do not
see LFE since I turned that off also.
Update - I hooked up a DVD player through optical and everything plays
fine. So it is the Gateway's settings. I looked everywhere but could
not find a way to release the basses.
That would have been my 2nd suggestion Good move on trying the DVD player.
