Subwoofer placement
G
Guest
Guest
Archived from groups: rec.audio.tech (More info?)
Hi!
Could you give me a tip on how to place my subwoofer so that i could
get most of it while it wouldn't be heard outside my room. What ir
mean is - when listening to music on 'social level' the music can not
be heard outside my room except deep lows made by subwoofer.
Whats more confusing I use it only for subtle bass pressence but it
'becomes' as twice as loud when I leave to other rooms... So as I
live in a flat I presume same effect applies to my neighbours upstairs
and downstairs. I Believe they wouldn't appreciate my listening
sessions :)
I've got AudioPro 'Sub Cinema' if it's important.
Thanks a lot
A
Cyrus
192
In article <97534bee.0502091532.219d901e@posting.google.com>,
arnis@grafton.lv (GeeTee) wrote:
> Hi!
> sessions :)
> Thanks a lot
> A
AFAIK There are only 2 ways to seperate low frequencies between spaces,
mass and/or dead air space. Sub frequencies travel easily through walls,
especially normal home walls.
Cyrus
*coughcasaucedoprodigynetcough*
G
Guest
Guest
Actually, a vacuum is even better! (Anyone for a Dewar HT room?)
Kal
G
Guest
Guest
>sessions :)
Not really. Low frequencies aren't very directional - it's why
sub-unit placement isn't critical.
Note that if you can HEAR the sub-woofer as a separate source, it's
way out of balance. Turn it down.
G
Guest
Guest
In article <97534bee.0502091532.219d901e@posting.google.com>, arnis@grafton.lv
says...
>Hi!
>sessions :)
Build a false floor and cieling to issolate your neighbors. Short of that,
there is not much you can do.
Alex
G
Guest
Guest
It's more like I feel it not 'hear' it :)
