Hello , i will explain my problem .
i decided to add another hard disk 1 tb , to my alrdy 500gb hdd , and when i wanted to format and add a new partition , i used the windows 7 CD , and i pressed custom :/ and it started installing windows on the 2nd hard disk which was meant to be a slave , i didnt want that and i canceled the installation , yes , i pressed cancel
now supposedly i tried to reboot , it showed bootmgr is missing error , i tried the windows disk again and clicked repair my computer , it gave me another error that it didnt recognize my windows version , i have tried everything on the net , i even tried to boot with my old hard disk without the new 1 , still no bootmgr , same thing with new HDd .
im not sure what can i do from here .
HDDs are set to AHCI mode ,
i cant access my data to back it up , and i cant use any of the two hard disks . i can see them both when i try to install windows , and both disk 0 and disk 1 have a partition with "system"
