Archived from groups: alt.cellular.ericsson (More info?)
I friend of mine has recently had a Sony Ericsson T610 with a Bluetooth
headset.
I was trying to help her setup voice tags so she could dial people using the
Bluetooth headset and voice tags. However, no matter what we did we just
couldn't get the voice tags to work.
Has anyone else got voice tags to work on the 610? How do you do it?
Any help or information will be gratefully received.
Thanks!
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.726 / Virus Database: 481 - Release Date: 22/07/2004
> headset.
> Thanks!
If its not dialing the number you've assigned the tag to when u speak,
it just repeats the name and beeps and goes back to standby, I know
exactly what it is.
I had this very same problem.
You need to make sure each contact in your phonebook has the default
number set correctly, such as mobile, home or work.
Once you do that, the voicetag will access the correct entry, and allow
you to select the mobile, home or work number you choose.
Strange that the manual doesn't tell you this, as I spent ages trying to
work it out.
