G
Guest
Guest
Hi,
I am using the Ultra 100 TX2 Controller to run two UDMA-66 HD's: Western
Digital (41 GB) and Quantum (15 GB). Now, since my system (WIN98SE) is on
another HD which is connected directly to the onboard IDE-controller (IBM
UDMA 100, 60GB) of my ASUS P4S333 board, it happens that the two other HD's
connected to the Promise-controller (which contain non-system relevant
files, only) are not being used for some time. For some reason they power
down and spin down after say some 15 minutes. When I then need data off them
they automatically power-up again.
All HD-power-down parameters in the board's bios as well as WIN98 are
disabled so I assume that the Promise-Controller itself tells the HD's to
power down.
Is there a way to switch this power-saving feature off, at all? First, I
always have to wait for the discs to power-up when I need them (which bugs
me), and second, the continuos off-on-off-on is definitely not going to
prolong my HDs' life.
Please help me in this matter!
Thanks from Germany
power down.
Thanks from Germany
