Sign-in / Sign-up
Moving hard drive to new motherboard
  • Windows 7
  • Hard Drives
  • Motherboards
Last response: in Windows 7
April 4, 2012 4:32:19 PM
I am doing a motherboard upgrade for a friend. I need to know how I can move his hard drive with his current OS instal to the new motherboard without having to do a fresh Windows 7 install. He has too much that cannot be replaced. Is there a way to do this?
More about : moving hard drive motherboard
April 5, 2012 7:10:35 AM
Just backup all files on another hard hdd/usb/dvd. Make a new install on your current HDD. Only way to do a fresh install of windows 7
m
l
a b V Motherboard
a b $ Windows 7
April 5, 2012 7:38:51 AM
Unless you replacing the mainboard with the same make/model you will have to do a fresh install there is really no way around it. I have even seen Windows 7 fail to boot when replacing a mainboard with the same make/model but newer revision. As stated by Redmar89 backup all important files then do a fresh install. Any programs will need to be reinstalled. Good luck.
m
l
