Tom's Hardware > Forum > Audio > Audio Technology > Problem with Harman Kardon AVR5 reloaded
Forum Audio : Audio Technology - Problem with Harman Kardon AVR5 reloaded
Archived from groups: rec.audio.tech (More info?)
I opened it up and none of the fuses were blown. Tried to turn it on
again and the DG1U relay clicks on when I hit the power button, the
power button briefly turns green, then the relay clicks off and the
power button goes back to red.
Does this mean the relay is blown? Can I replay this with one
purchased at Radio Shack and some solder? What about the A35-326c-u
w/ thermal fuse? It's right next to the relay.
Any help would be appreciated in bringing this receiver back to life -
otherwise I guess it gets kicked to the curb.
On Sat, 5 Feb 2005 05:27:04 -0600, "Mark D. Zacharias"
<mzacharias@yis.us> wrote:
>Seems the protection circuit is activating. This is normally caused by a
>blown amp channel or a problem in the power supply. You can try looking for
>a blown fuse or anything obviously wrong visually. Otherwise your only
>practical options are to pay to have it repaired, or buy a new receiver. If
>it isn't worth spending perhaps 150.00 or more, replace it.
>Mark Z.
><loafergopher@bayouyahoo.com> wrote in message
>news:g5l701p9smn057bu3dmkfvaa3206l7bmov@4ax.com...
>>I have a Harmon Kardon AVR-5 that died last year. When plugged in,
>> the little red light on the power button lights up. When this button
>> is pushed, it goes to green briefly with that brief "oomph" coming
>> over the speakers when the receiver is switched on, but then the power
>> goes right off, the button returning to red.
>> Any ideas on what is broken? Is it easy to fix and/or get parts for?
>> Or is it a junker? My experience is on the computer repair side of
>> things - not really audio equipment.
>> Thanks.
Sponsored Links
There are 1552 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Latest best answer
Speaker recommendation
By astrallite, 2 days ago:
Try this: Sherwood 5.1 receiver ($172 shipped). http://www.amazon.com/Sherwood-RD6 [...] 05&sr=8-10 Energy Take 5s ($199) http://www.newegg.com/Product/Prod [...] 20take%205 Dayton Sub 80 ($75) http://www.parts-express.com/pe/sh [...] er=300-631 This should come out to $450. As far as Bose goes, unless you are talking about the x01 series from the 70s (which were pretty good back then), their modern speakers are just clock radios designed for decor-conscious older people who need invisible speakers. Acoustically they are no better than your typical PC satellite speakers (I'm being generous here, they are probably worse than high end PC speakers); they really are nothing more than a couple of thin plastic cans. The satellites replacement drivers that you can request from Bose cost $2 (low quality untreated paper drivers) and the satellites themselves are built with thin cheap plastic enclosures. That should give you an idea of build quality...it's basically a product with 95% markup. I doubt their $1000 acoustimass systems cost more than $50 to manufacture. To give you an idea what a value product is, in my bedroom I have a pair of Ascend Sierra 1 bookshelf speakers that go for $800/pair. The tweeters that Ascend purchase from SEAs of Norway cost $200/each, or $400/pair. Include the cost of diamond drill bits for industrial cutting tools needed to cut through 3/4" solid bamboo enclosures, the long-throw injection-molded poly midrange/woofers, and a high gloss piano black automotive finish and you are talking about $600 manufacturing costs. After shipping and handling, I doubt they make more than 25%, a fraction of Bose's margins. It's called name brand markup. That said, it's your money, if you want to buy it, it's your prerogative. And to your room, it's about 11x11 as I understand it? It's not THAT small. I'm running a pair of bookshelf speakers that run 60lbs on 80lbs of solid metal stands and they work fantastic in a 166sq foot office (only slightly bigger than your room).
