Tom's Hardware > Forum > Audio > Audio Technology > Onkyo TX-810 problem
Forum Audio : Audio Technology - Onkyo TX-810 problem
Archived from groups: rec.audio.tech,sci.electronics.misc (More info?)
Hi,
My wife's 15-year old ONKYO TX-810 has developed what seems to be a power
problem. It turns itself on and off every few seconds, eventually leading to
a total shutdown.
We took it into an electronics shop and they told us that the power supply
needed some new solder joints. Not too expensive, so we said "sure".
Then they came back and said it didn't fix the problem -- now we needed a new
"Display Circuit Assembly". Onkyo says this part is no longer manufactured.
Now the electronics store says there is nothing they can do, and want us to
pay for the original repair.. even though it didn't fix anything!
Can anyone shed some light on this? Is the DCA an actual part? What does it
have to do with power issues?
And finally, do you think I should take the receiver to a different shop?
(This shop is listed on ONKYOs site as an authorized service center, so I
assumed they were honest. Were my assumtpions wrong?)
Thanks,
Michael Hoffman
Sponsored Links
If you took the set to the Onkyo authorized service, this is about the best
you can do! The manufactures are normally very picky about who they
contract to do their work.
What you can do, is get the Onkyo part number for the part you need, and
start searching for it yourself. You can first start by calling Onkyo
directly, and see what they say. Then you can also do a search on the net,
using search engines, to see if there are any sites or listings that would
have what you are looking for.
You have to consider that after a set is about 5 to 7 years old, most
manufactures will no longer have parts for it.
Jerry G.
"Michael Hoffman" <mrh@panix.com> wrote in message
news:cura4k$mcs$1@reader2.panix.com...
Hi,
to
a total shutdown.
new
it
Thanks,
Michael Hoffman
Reply to Anonymous
They can't make you pay for the complete repair if they didn't fix it - I
don't see how. I've seen 810's with bad solder connections, I'm suspicious
of their diagnosis on the display tube.
Mark Z.
Authorized Onkyo Servicer - Wichita, KS.
> Hi,
> to
> a total shutdown.
> new
> manufactured.
> to
> it
> Thanks,
> Michael Hoffman
Reply to Anonymous
There are 1309 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Latest best answer
Speaker recommendation
By astrallite, 2 days ago:
Try this: Sherwood 5.1 receiver ($172 shipped). http://www.amazon.com/Sherwood-RD6 [...] 05&sr=8-10 Energy Take 5s ($199) http://www.newegg.com/Product/Prod [...] 20take%205 Dayton Sub 80 ($75) http://www.parts-express.com/pe/sh [...] er=300-631 This should come out to $450. As far as Bose goes, unless you are talking about the x01 series from the 70s (which were pretty good back then), their modern speakers are just clock radios designed for decor-conscious older people who need invisible speakers. Acoustically they are no better than your typical PC satellite speakers (I'm being generous here, they are probably worse than high end PC speakers); they really are nothing more than a couple of thin plastic cans. The satellites replacement drivers that you can request from Bose cost $2 (low quality untreated paper drivers) and the satellites themselves are built with thin cheap plastic enclosures. That should give you an idea of build quality...it's basically a product with 95% markup. I doubt their $1000 acoustimass systems cost more than $50 to manufacture. To give you an idea what a value product is, in my bedroom I have a pair of Ascend Sierra 1 bookshelf speakers that go for $800/pair. The tweeters that Ascend purchase from SEAs of Norway cost $200/each, or $400/pair. Include the cost of diamond drill bits for industrial cutting tools needed to cut through 3/4" solid bamboo enclosures, the long-throw injection-molded poly midrange/woofers, and a high gloss piano black automotive finish and you are talking about $600 manufacturing costs. After shipping and handling, I doubt they make more than 25%, a fraction of Bose's margins. It's called name brand markup. That said, it's your money, if you want to buy it, it's your prerogative. And to your room, it's about 11x11 as I understand it? It's not THAT small. I'm running a pair of bookshelf speakers that run 60lbs on 80lbs of solid metal stands and they work fantastic in a 166sq foot office (only slightly bigger than your room).
Related Content
