Hello, Im having an issue with sound interference. I have been getting an annoying, loud buzzing sound from my speakers on my monitor When I connect the green AV cables and continues to make the sound regardless if i mute the system. I think it may be DPC latency from what I have seen others post about. But when I use the DPC checker its pretty normal in the 100-200range.
I've tried several things such as: disabled my Mic, moved any phones that were close by away, take out power to the TV and other electronics, but still no help.
I have A VIZIO 32' M320NV. and a Viewsonic Monitor. I'm pretty sure the problem isn't either the TV or monitor because I get the same interference when I connect speakers to the PC.
My Specs for my PC are
Sabertooth x58Mobo
Intel 17 970
1 Geforce GTX 570
16gigs of DDR3 Ram
I have had this issue for a year now. ASUS does nothing for me and refers me nowhere. I have tried everything from RMAing my board, trying different drivers, disabling intel speed step, getting an independent sound card, ect. If someone could please help me figure this out, it would make my life alot easier. It is too much to hear that static come from the monitor whenever I boot something up that requires the system to work (ex) starting an online game up).
Sabertooth x58Mobo
Intel 17 970
1 Geforce GTX 570
16gigs of DDR3 Ram
System Information
Time of this report: 7/27/2011, 16:09:31
Machine name: KINGDANGALANG
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110408-1631)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 11/16/10 20:16:12 Ver: 08.00.15
Processor: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz (8 CPUs), ~3.1GHz
Memory: 6144MB RAM
Available OS Memory: 6136MB RAM
Page File: 5193MB used, 7075MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: The file ksaud.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 570
Manufacturer: NVIDIA
Chip type: GeForce GTX 570
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1081&SUBSYS_15723842&REV_A1
Display Memory: 4059 MB
Dedicated Memory: 1248 MB
Shared Memory: 2811 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: M320NV
Monitor Id: VIZ0070
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.7533 (English)
Driver Version: 8.17.12.7533
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 5/25/2011 02:09:12, 15223912 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-53C1-11CF-9F46-7E351FC2C535}
Vendor ID: 0x10DE
Device ID: 0x1081
SubSys ID: 0x15723842
Revision ID: 0x00A1
Driver Strong Name: oem2.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section032:8.17.12.7533ci\ven_10de&dev_1081
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor Name: ViewSonic VX1962wm Series
Monitor Model: VX1962wm
Monitor Id: VSCD920
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: DVI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1081
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_10438436&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6037 (English)
WHQL Logo'd: Yes
Date and Size: 1/29/2010 02:48:44, 2260256 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers (SB X-Fi Go! Pro)
Default Sound Playback: No
Default Voice Playback: Yes
Hardware ID: USB\VID_041E&PID_30DD&REV_0171&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: ksaud.sys
Driver Version: 6.00.0001.0483 (English)
WHQL Logo'd: No
Date and Size: 8/11/2010 10:51:48, 1587968 bytes
Other Files:
Driver Provider: Creative Technology Ltd.
Cap Flags: 0xF1F
HW Memory: 0
Description: M320NV-1 (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0018&SUBSYS_10DE0101&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.02.0023.0003 (English)
WHQL Logo'd: Yes
Date and Size: 5/25/2011 02:09:17, 174184 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (USB2.0 Audio Device)
Default Sound Capture: Yes
Default Voice Capture: No
Driver Name: USBAUDIO.sys
Driver Version: 6.01.7601.17514 (English)
Date and Size: 11/20/2010 23:23:47, 109696 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: z (SB X-Fi Go! Pro)
Default Sound Capture: No
Default Voice Capture: Yes
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Sound Blaster X-Fi Go! Pro
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x041E, 0x30DD
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0745
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3A36
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 11/20/2010 23:23:47, 343040 bytes
| Driver: usbd.sys, 7/13/2009 20:06:23, 7936 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 11/20/2010 23:23:47, 33280 bytes
| Driver: kbdclass.sys, 7/13/2009 21:48:04, 50768 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/13/2009 19:19:57, 105472 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/13/2009 20:00:20, 31232 bytes
| Driver: mouclass.sys, 7/13/2009 21:48:27, 49216 bytes
+ Logitech HID-compliant G3/MX518 Optical Mouse
| Vendor/Product ID: 0x046D, 0xC051
| Matching Device ID: hid\vid_046d&pid_c051
| Upper Filters: LMouFilt
| Lower Filters: LHidFilt
| Service: mouhid
| Driver: LHidFilt.Sys, 4/30/2011 07:59:22, 66840 bytes
| Driver: LMouFilt.Sys, 4/30/2011 07:59:22, 60184 bytes
| Driver: LkmdfCoInst.dll, 4/30/2011 07:59:22, 1845528 bytes
| Driver: LMouFiltCoInst.dll, 4/30/2011 07:59:32, 55064 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/20/2010 23:23:47, 63360 bytes
| Driver: sermouse.sys, 7/13/2009 20:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 24.5 GB
Total Space: 305.1 GB
File System: NTFS
Model: WDC WD3200AAKS-00UU3A0 ATA Device
Drive: D:
Model: HP DVD Writer 1260t ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 147456 bytes
System Devices
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_84361043&REV_00\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 122368 bytes
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_82D41043&REV_00\3&11583659&0&E8
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/13/2009 20:06:27, 30720 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 325120 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 343040 bytes
Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_13\3&11583659&0&A1
Driver: n/a
Name: JMicron JMB36X Controller
Device ID: PCI\VEN_197B&DEV_2362&SUBSYS_84601043&REV_10\4&820CCE8&0&00E4
Driver: C:\Windows\system32\DRIVERS\jraid.sys, 1.17.0056.0002 (English), 5/31/2010 01:44:51, 116848 bytes
Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_82D41043&REV_00\3&11583659&0&D7
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 52224 bytes
Name: Intel(R) ICH10 Family SMBus Controller - 3A30
Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_82D41043&REV_00\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_836B1043&REV_13\3&11583659&0&38
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 184704 bytes
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&1B359D48&0&10F0
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 229888 bytes
Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_82D41043&REV_00\3&11583659&0&EF
Name: Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26
Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_82D41043&REV_00\3&11583659&0&FD
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 21:45:45, 12352 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 21:45:46, 48720 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 21:52:21, 24128 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 23:23:47, 155520 bytes
Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_836B1043&REV_13\3&11583659&0&18
Name: Realtek PCI GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8167&SUBSYS_820D1043&REV_10\4&1B359D48&0&08F0
Driver: C:\Windows\system32\DRIVERS\Rt64win7.sys, 7.18.0322.2010 (English), 3/22/2010 05:57:20, 347680 bytes
Driver: C:\Windows\system32\RtNicProp64.dll, 1.02.0000.0003 (English), 12/3/2009 05:27:28, 74272 bytes
Driver: C:\Windows\system32\RTNUninst64.dll, 1.00.0000.0005 (English), 1/5/2010 12:39:36, 107552 bytes
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_82D41043&REV_00\3&11583659&0&D2
Name: Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20
Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_82D41043&REV_00\3&11583659&0&FA
Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 2 - 3409
Device ID: PCI\VEN_8086&DEV_3409&SUBSYS_836B1043&REV_13\3&11583659&0&10
Name: NVIDIA GeForce GTX 570
Device ID: PCI\VEN_10DE&DEV_1081&SUBSYS_15723842&REV_A1\4&2F1C4782&0&0018
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.7533 (English), 5/25/2011 02:09:11, 213096 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/25/2011 02:09:12, 304068 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 5/25/2011 02:09:11, 15511 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0012.7533 (English), 5/25/2011 02:09:11, 12392 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.7533 (English), 5/25/2011 02:09:12, 13206120 bytes
Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 5/25/2011 02:09:14, 67176 bytes
Driver: C:\Windows\system32\nvapi64.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:11, 2644584 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:11, 18583144 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:11, 7123560 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0012.7533 (English), 5/25/2011 02:09:11, 2212968 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:12, 2943592 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:12, 15223912 bytes
Driver: C:\Windows\system32\nvinfo.pb, 5/25/2011 02:09:12, 7384 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:13, 22286952 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:14, 8863336 bytes
Driver: C:\Windows\SysWow64\OpenCL.dll, 1.00.0000.0000 (English), 5/25/2011 02:09:14, 57960 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:11, 2335848 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:11, 13011560 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:11, 5301352 bytes
Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0012.7533 (English), 5/25/2011 02:09:11, 2082408 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:12, 2804328 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:12, 11992680 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:13, 16456296 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0012.7533 (English), 5/25/2011 02:09:13, 6555240 bytes
Driver: C:\Windows\system32\nvdispco6420150.dll, 2.00.0015.0000 (English), 5/25/2011 02:09:12, 1496168 bytes
Driver: C:\Windows\system32\nvgenco642090.dll, 2.00.0009.0000 (English), 5/25/2011 02:09:12, 1427048 bytes
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_82D41043&REV_00\3&11583659&0&D1
Name: Intel(R) ICH10R LPC Interface Controller - 3A16
Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_82D41043&REV_00\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 21:48:27, 15424 bytes
Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_836B1043&REV_13\3&11583659&0&08
Device ID: PCI\VEN_10DE&DEV_0E09&SUBSYS_15723842&REV_A1\4&2F1C4782&0&0118
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_82D41043&REV_00\3&11583659&0&D0
Name: Intel(R) 5520/5500/X58 I/O Hub Throttle Registers - 3438
Device ID: PCI\VEN_8086&DEV_3438&SUBSYS_00000000&REV_13\3&11583659&0&A3
Driver: n/a
Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3405
Device ID: PCI\VEN_8086&DEV_3405&SUBSYS_836B1043&REV_13\3&11583659&0&00
Driver: n/a
Name: Renesas Electronics USB 3.0 Host Controller
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_84131043&REV_03\4&CF85AA7&0&0010
Driver: C:\Windows\system32\DRIVERS\nusb3xhc.sys, 2.00.0004.0000 (English), 4/27/2010 09:30:52, 184968 bytes
Name: Intel(R) ICH10 Family PCI Express Root Port 5 - 3A48
Device ID: PCI\VEN_8086&DEV_3A48&SUBSYS_84361043&REV_00\3&11583659&0&E4
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_82D41043&REV_00\3&11583659&0&EA
Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_13\3&11583659&0&A0
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_82D41043&REV_90\3&11583659&0&F0
Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_84361043&REV_00\3&11583659&0&E0
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_82D41043&REV_00\3&11583659&0&E9
Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_13\3&11583659&0&A2
Driver: n/a
Name: Marvell 91xx SATA 6G Controller
Device ID: PCI\VEN_1B4B&DEV_91A3&SUBSYS_84381043&REV_11\4&37C265C7&0&0008
Driver: C:\Windows\system32\DRIVERS\mv91xx.sys, 1.00.0000.1034 (English), 12/25/2009 03:05:40, 297512 bytes
Driver: C:\Windows\system32\DRIVERS\mvxxmm.sys, 1.00.0000.1200 (English), 12/25/2009 02:45:16, 5632 bytes
Driver: C:\Windows\system32\mv91xxm.dll, 1.00.0000.0001 (English), 12/25/2009 02:45:16, 35840 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17514
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17514
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17514
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17514
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17514
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17514
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17514
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17514
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17514
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17514
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17514
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17514
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17514
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17514
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17514
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17514
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17514
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17514
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17514
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17514
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17514
Audio Capture Sources:
Microphone (USB2.0 Audio Device,0x00200000,0,0,qcap.dll,6.06.7601.17514
z (SB X-Fi Go! Pro),0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17514
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
SB X-Fi Go! Pro,0x00200000,4,3,ksproxy.ax,6.01.7601.17514
USB2.0 1.3MP UVC Camera,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
USB2.0 Audio Device,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
NVIDIA High Definition Audio,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Optical Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17514
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17528
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17528
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17528
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17528
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17514
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: M320NV-1 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Speakers (SB X-Fi Go! Pro),0x00200000,1,0,quartz.dll,6.06.7601.17514
M320NV-1 (NVIDIA High Definitio,0x00200000,1,0,quartz.dll,6.06.7601.17514
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
