lnb problem?
Forum Home Cinema Equipment : 4DTV Satellite - lnb problem?
Archived from groups: alt.video.satellite.4dtv (More info?)
I have a sidecar, last week suddenly there was a drop in signal quality,
about 10 - 20 in many channels. I adjusted the dish and skew to the best,
but the problem remains.
In the analog side now I have some sparkles.
Is there a kind of lnb failure which explains this?
Uniden 4400 super
905 sidecar
LNB Pansat 17 K digital read 8 years old
10 ft dish
Guadalajara, Mexico
Sponsored Links
On Sun, 18 Jul 2004 12:09:50 -0400, "SergioRaul"
How are your even/odd channels on analog?
Can you give some specific examples?
Maybe your polar motor is sticking? Maybe you have a hornet's nest
inside throat of feed horn?
>Uniden 4400 super
>905 sidecar
>10 ft dish
>Guadalajara, Mexico
Reply to Anonymous
Good answer new sun,
also, the hot weather can effect LNB performance.
Reply to Anonymous
Well yes, but "Pedro" should have been well aware of this angle.
Actually, I suspect heat affects the incoming sat-signal more so than
LNB; get a bigger dish, and your problems go away.
In other words, I think there is a sales myth [lie] about heat effects
on LNBs; if you have a decent LNB, don't buy a new one.
Reply to Anonymous
Tom's Hardware > Forum > Home Cinema Equipment > 4DTV Satellite > lnb problem?
There are 610 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
