"TDMedia" <TDMedia@optonline.net> wrote in message
news:1109598876.492560.142670@o13g2000cwo.googlegroups.com
> HELP! My Onkyo TA-201 cassette deck (only about three years old) has
> started to eat tape!
> Will demagnetizing help?
No.
>Do the heads need to be realigned?
Probably not unless they are bent up like pretzels.
Probable faults would be in the reel drive subsystem
news:1109601899.135717.221580@g14g2000cwa.googlegroups.com
> Sorry, I'm not a real techie when it comes to gear.
Then you need a techie to fix the problem you have.
> Can you expand on that?
Cassette tape is pulled through the player by a mechanism that engages the
little internally-toothed wheels that have the tape wrapped around them.
This mechanism can get broken, worn out, and/or dirty. When its not working
right, the machine tends to eat up tapes and trash them.
In <1109598876.492560.142670@o13g2000cwo.googlegroups.com>, on 02/28/05
No, but you should occasionally demagnetize the deck for other reasons.
Only if the deck has been subjected to some severe physical trauma or
someone has been inside messing with things they don't understand.
Over 90% of tape "eating" problems go away after I clean the deck. The
"pressure roller" (that little round, black thing near the silver,
spinning shaft) should be a uniform dull black color. If it is brown or
shinny, assume that is your problem until proven otherwise. Cassette
cleaner tapes are not very effective for cleaning the pressure roller.
spam: uce@ftc.gov
wordgame:123(abc):<14 9 20 5 2 9 18 4 at 22 15 9 3 5 14 5 20 dot 3 15
13> (Barry Mann)
[sorry about the puzzle, spammers are ruining my mailbox]
In article <1109598876.492560.142670@o13g2000cwo.googlegroups.com>,
> Will demagnetizing help? Do the heads need to be realigned?
Yes, but not this problem. Yes, but it will not effect this
problem. You should clean and demag you tape deck as part
of routine operation. You should have the heads aligned
every few years, more often if you do professional grade
work.
The problem you have is that your take-up reel clutch
is slipping. That usually means you have worn out a
cheap tape deck, or you have an expensive tape deck
that is past due for routine maintenance.
The take-up reel clutch can fail like this for many
reasons. It might need cleaning. It might need adjusting.
You might need belts. There might be a rubber piece that
has dried out or wore out. This is likely a job for a
service tech.
-john-
John A. Weeks III 952-432-2708 john@johnweeks.com
Newave Communications http://www.johnweeks.com ======================================================================
On 28 Feb 2005 05:54:36 -0800, "TDMedia" <TDMedia@optonline.net>
No, demag and realignment aren't related to this. Other posters
answered this well.
If it does it on several tapes, then the tape path should be cleaned
and a tech should check to see what may be preventing the takeup reel
side from pulling the tape onto the reel. As other posters indicated,
there could be a problem with a bad belt, gear or rubber wheel on the
takeup side.
If it did this just with one tape, then the tape may have been bad.
If the takeup reel side had difficulty turning due to pressure on the
tape, then that can cause this problem even if the deck is OK.
Gary E
|Gary A. Edelstein
|edelsgNO@SPAMyahoo.com.invalid (remove NO SPAM and .invalid to reply)
|"We have met the enemy and he is us." - Walt Kelly's Pogo
Demagnetizing will not help for stopping the tapes from being damaged. The
usual cause are worn parts in the tape path mechanism.
You will have to give the machine out for proper service, if you are not
trained and properly equipped to do this type of service yourself.
Jerry G.
news:1109598876.492560.142670@o13g2000cwo.googlegroups.com...
Press Eject and preferably remove cassette deck outer, transparent dust
cover (probably slides off if persuaded).
With no cassette present, press Play button.
See if there is rotation (or an adequate torque) on take-up platter.
[You might have to keep pressing Play as the auto mechanism logic will
possibly "know" it is not loaded and "think" it is not meant to run!]
This will prove that the gearing to take-up platter (or via a direct-drive
motor) is working, uninhibited.
If it is sluggish or juddery or sticking in mid-function, therein lies the
cause - probably dirt, foreign bodies or likely worn belt/s. Does it Fast
Forward?
I suggest it is beyond your lay ability to repair this detail.
If OK, then gently but thoroughly clean the tape guides, heads and capstan
spindle, pressure roller, with cotton buds soaked in surgical spirit or
ethyl alcohol. If bud floss gets oxide-brown, discard and use a fresh one.
Cleaning is over when the bud looks untarnished.
Let dry. Replace cover if taken off, in same mode.
Do this maintenance every 20 tapes anyway. Demag if you know what you're
doing.
