Tom's Hardware > Forum > Mobility Brands > Ericsson > Problem connecting SE T630 to 2 different PCs via BlueTooth
Forum Mobility Brands : Ericsson - Problem connecting SE T630 to 2 different PCs via BlueTooth
Archived from groups: alt.cellular.ericsson (More info?)
All, hope someone can help!
I am having some problems connecting my T630 to my home and work PCs.
I have connected up fine at home (WinXP SP2 with the MS Stack) and all
is working fine. The PC registers ok on the handset as NEO which is
the BT name I gave it.
When I come to connect it to my work PC (Win 2000 SP4 with the Jon's
Guide installation of BT) it connects up OK but registers the PC as
NEO as well, not ARCHITECT which is what I have set up the BT name as.
If I connect to the Win2K machine it overwrites the NEO device as the
Win2K machine and when I get home I have to delete the device and
re-pair with NEO to get it to work.
Am I doing something wrong? Is it possible to pair the phone with 2
different PCs?
TIA
Shevek
Get DigiGuide - a downloadable desktop PC TV and Radio Guide
http://getdigiguide.com/?p=1&r=31493
Sponsored Links
On Wed, 18 Aug 2004 14:16:05 +0100, Shevek
>different PCs?
Think I may have just figured it! I am using the same BT dongle for
both PCs - so I guess it has the same device address irrelevant of
which PC it is connected to. Can anyone confirm this?
If this is the case, I guess I will have to re-pair it for each
machine....
Hmm or maybe buy another dongle....
Shevek
Reply to Anonymous
>>different PCs?
> machine....
You are right in your assumption.
Before buying another dongle, you should set up both PC's with the same
BT-name and BT PIN code. Then pair from both, and test if it is
possible to fool the phone into using both PC's without re-pairing.
Reply to Anonymous
>>>different PCs?
>> machine....
That's just far too clever ;-)
Good idea, I'll give it a go!
Shevek
Reply to Anonymous
There are 1088 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
