Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I am trying to use the mn-700 to extend my current
network. I would like to place the mn-700 in one room with
both my Xbox and a PC and connect to my other wireless
router in another room. Is this possible to do with out
having to connect a wire from one room to the other?
the 700 will not bridge wirelessly, it must be hardwired. what you need is
an XBOX adapter - MN-740. you can configure that on the XBOX, then connect a
switch or hub to it and connect both the XBOX and the PC to the switch.
> David.
What if I configure both routers as AP's will that solve
the issue. I have one mn-500 and one mn-700. Or should I
just return one the routers and get the xbox adapter?
David
>-----Original Message-----
what you need is
to the switch.
with
>> David.
> Barb Bowman
> Expert Zone Columnist
> http://www.microsoft.com/windowsxp/expertzone > MS-MVP (Windows)
return the 500 and get the XBOX adapter
> David
>> need is an XBOX adapter - MN-740. you can configure that on the
>> XBOX, then connect a switch or hub to it and connect both the XBOX
> with
>>> David.
>> Barb Bowman
>> http://www.microsoft.com/windowsxp/expertzone >> MS-MVP (Windows)
