Latest Reviews & Articles
Overclocking Core 2 Duo: Power Versus Performance
Intel's fastest Core 2 Duo, the E8600, runs at 3.33 GHz. But if you're a performance-hungry power user, we found that you can actually increase the chip's efficiency by overclocking it, thanks to 45 nm manufacturing and plenty of built-in headroom. Read more
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
All the Reviews & Articles
Tom's Hardware > Forum > Audio > Audio Technology > Sony Fontopia Plus earphones does not like mains power sup..
Archived from groups: rec.audio.tech (More info?)
I bought some Sony Fontopia Plus (MDR-ED21LP) earphones from Argos UK
a few days ago. I've noticed something very odd. When I use them with
an Apple iPod which is plugged into the mains (i.e. on charge) I hear
continuous background noise, like the background static noise you used
to get from a cheap portable tape player from years ago.
If I disconnect the iPod from the mains supply then the problem goes
away completely. If I plug it back in, the problem reappears. Also, if
I touch a metal part of my iPod, such as the casing or the remote
control, then that also removes the background noise completely!
I've noticed a similar thing with my laptop. If I use these earphones
with my Vaio while it is plugged into the mains then I get the same
problem. If I disconnect my Vaio from the mains then the problem goes
away completely. Also, if I touch any metal part of my Vaio (eg touch
the firewire port with my finger) then that removes the background
noice from the earphones too, exactly the same effect as touching my
iPod metal casing.
I have tried another pair of headphones and the problem does not occur
at all, even if I plug the Vaio into the mains supply.
So these Fontopia earphones don't seem to like the UK power supply!
Bizarre! Does anyone know if it's a grounding issue, or a frequency
interference issue?
Also, is this is a common issue with headphones, or with Fontopia
brand, or with quality control?
Thanks, Ant
Sponsored Links
This sounds like a grounding issue. You should speak to the sales people
where you bought it.
Jerry G.
"Ant" <pawnpacer@yahoo.com> wrote in message
news:1e41930a.0503051547.49e09865@posting.google.com...
iPod metal casing.
interference issue?
Thanks, Ant
Reply to Anonymous
This would be in comparison with the phones that came with the iPod, right?
I've never heard these relatively low-end phones, but if they have the "Sony
Sound". they are probably a little hot on the high end. This means that any
hissing coming from within the player would be accentuated compared to
headphones with neutral sound or sound that is rolled-off on the high end.
> away completely.
This means to me that the iPod is picking up noise from its line-operated
power supply, or something else attached to the power supply. My
recollection is that the iPod normally picks up power from its docking
station which includes other kinds of connections, including computer port
connections for either USB or Firewire. If these connections are connected
to a computer, they could be adding to the noise situation. You might want
to see what disconnecting them accomplishes. However I also seem to recall
that the docking station may obtain power via them, so disconnecting them
might not be a long term solution.
This suggests to me that you have a problem with picking up noise via one of
the connections to the iPod, all of which are routed thorugh the docking
station. When you touch the case you may be partially grounding it through
your body.
I've worked with iPods, and this is not normal. It suggests a fault
someplace, but as you can see there are many possible sources of problems,
some of which may be hard to separate out.
> away completely.
You may have some external interferance source in the room or nearby, or
your power line may be picking up noise from an external source and dumping
it into your computer gear.
> iPod metal casing.
YOu shouldn't need to ground these components to have noise-free operation.
What happens if you try to use your iPod at someone else's house?
I explained that at the beginning of the post.
> interference issue?
I suspect its environmental. Lots of people use any given model of Sony
phones with Viao computers and iPods. I doubt that ehty are all having
problems.
I suspect your environment. There could be something odd with how power is
grounded in yourself, or something like that.
Reply to Anonymous
- 0 +
"Arny Krueger" <arnyk@hotpop.com> wrote in message news:<rMmdndf4-JgClbbfRVn-hw@comcast.com>...
> > away completely.
> your body.
> > away completely.
> > iPod metal casing.
> > interference issue?
> problems.
Thanks for the reply. Just to add:
1) I've tried the headphones with my vaio while it has been plugged
into the mains at another location (about 6 miles away), and I
observed the exact same problem.
2) The other phones I tried (which do not have the problem) were also
Sony (some larger headphones in this case). I only briefly tried the
supplied Apple earphones a couple of years ago and not used those
since. I'll try those out and post a follow up.
So far the only common factors I can see are the earphones and the UK
power supply frequency (not sure about electricity provider).
Ant
Reply to Ant
There are 752 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
