Solved
Wireless range walls problem
Last response: in Wireless Networking
Hello,
Right now I have a very very bad wireless router don't even remember the name, I have problems with connectivity and signal. The problem that I have in my house is that from the place where I have my network stuff to my room I have a couple of walls besides a long distance.
I was planning to buy this router http://www.microcenter.com/single_product_results.phtml... but I read on internet that to increase the range a dual band could be a better option so I took a look to this: http://www.microcenter.com/single_product_results.phtml....
My questions are:
1. Is it ok the assumption that dual band will give me a better range through walls, besides a better range?
2. Which of the routers that I mentioned is better?
3. Could you suggest me a better router besides the 2 routers that I mentioned above?
Thanks in advance,
RV
how many walls are we talking about between your computer and the router?
what type of walls? drywall, brick, concrete
are there any bathrooms between your computer and the router?
is the a water heater between your computer and the router?
1) About 5 walls
2) Concrete the 5 walls
3) No bathrooms
4) No water heater
Thank you so much.
RV
Related ressources
1) About 5 walls
3) No bathrooms
4) No water heater
Thank you so much.
RV
Ask the community
