I currently have 512rdram 4x128 and wanted to do an upgrade. I was wondering what is the difference between ECC and NonECC? The ram I'm currently using is NonECC.
I personally use my comp for gaming and 3D design. Any ideas which I should get? I use the Intel I850GB motherboard with P4 1.4ghz chip.
You have exceeded the limit use of your current pointing device, reboot NOW!
