Tom's Hardware > Forum > Home Cinema Equipment > 4DTV Satellite > Radar Interference on 4ghz.satellite TVRO systems
Forum Home Cinema Equipment : 4DTV Satellite - Radar Interference on 4ghz.satellite TVRO systems
Archived from groups: alt.video.satellite.mpeg-dvb,alt.satellite.tv,alt.video.satellite.4dtv,alt.satellite.tv.forsale (More info?)
1. There have been several previous posts by individuals receiving
temporary external interference excluding terrestrial interference on
their 4 ghz. satellite tv systems.
2. Two of the most probable sources of the interference is airborne and
marine radar. C band lnbs have a wide bandpass 2.8 -4.8 ghz. The
satellite tv receiver is FM and susceptible to front end signal
overload. The receiver will process the strongest signal received.
3. Coastal and marine navigational radar frequencies are 2,900-3,650
mhz. which are slightly below the 3,700 mhz. beginning range of C band
downlinked signals. Possible interference from marine water and
airborne radar may adversely affect TVRO transponders 1-5. The airport
altimeter band 4,250-4,400 mhz. will affect TVRO channels 22-24 at sites
located near airports. These frequencies are slightly above the 4,200
mhz. TVRO ending range.
4. The solution is to narrow the bandpass of signals entering the C
band lnb. Microwave Filter <www.microwavefilter.com > sells an out of
band interference filter designed specifically for these interference
sources.
Sponsored Links
On Thu, 04 Nov 2004 18:02:27 -0500, john wilson <jwilson9@erols.com>
>sources.
This filter WILL work.
http://www.chesapeake.net/~scambro [...] rance.html
I do not recall the satellite.
scambron
Reply to Anonymous
On Fri, 05 Nov 2004 03:25:43 GMT, scambron@chesapeake.net (scambron)
>>sources.
>http://www.chesapeake.net/~scambron/plots/interferance.html
>scambron
Yikes, cheaper to build a screen!!!
Reply to Anonymous
There are 969 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
