S Sattan Honorable May 24, 2012 1 0 10,510 May 24, 2012 #1 Is there any way to fix the ethernet plug without having to take it off?
T tomatthe Distinguished Mar 3, 2010 1,027 0 19,660 May 24, 2012 #2 No, you can cut the end off and put a new one only fairly easily if you have the right tools though. Most people would probably just throw a bad cable away since they are so cheap though. Upvote 0 Downvote
