Power Supply?
Forum CPU & Components : Other Components - Power Supply?
Hi,
Here's what I have:
Windows XP
AMD Athlon@900MHZ
2HDD (1-30GB 5400RPM, 2-20GB 5400RPM)
512MB RAM
NVIDIA TNT2 M64, 32MB
CDROM and CDRW
ADSL Internet Connection
PSU = 250Watts
The problem is:
My computer restarts byitself, as much as 3 times in a row!, errors pop out every hour or so...and PSU get real hot.
So I turn on de AC in my room, and the errors stop a little bit, the PSU cools down, but computer still restarts when I use Heavy apps or have to many windows openend.
Im pretty sure my problem is the PSU, but I dont really know much about them..can someone, suggest what size PSU I should, if this is the problem?
RGDS
Eric
Sponsored Links
Quality of PSU is very important too. Enermax make very high quallity PSU. I would suggest you to get an ENERMAX EG365P.
Reply to upec
Thanks for your reply, I couldnt find Enermex, but did find one with the brand CodeGen model: 200XA...is this good enough for my needs??
RGDS
Eric
Reply to EricHansen
YOu will need at least 300 Watt. You can get an Enermax PSU from newegg.com.
Reply to upec
Just to add, 250W isn't enough to power the components you have. That's why it's overstressed. And, the spelling is <b>ENERMAX</b>, not <b>Enermex</b>. It could've been the reason you didn't find it.
Bryan
<font color=red><A HREF="http://www.btvillarin.com" target="_new">btvillarin.com</A> - My Windows XP-based Website</font color=red>
Reply to btvillarin
Thanks guys for all your help, I got my hand on an EnermAX ;) @300W
And everything is running very smoothly now, and best of all, Its not overheating like before...thanks for all the help.
RGDS
Eric
Reply to EricHansen
Nice. I hope we don't hear of any problems from you anytime soon...heh heh heh... :wink:
Later,
Bryan
Reply to btvillarin
Tom's Hardware > Forum > CPU & Components > Other Components > Power Supply?
There are 1362 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
