Solved
Laptop wireless turning off whenever I switch to battery power
Hello,
As the title suggests, my laptop always automatically disconnects from my wireless when I switch to battery and unplug from the power cable. I then have to restart because my laptop doesn't find any wireless adapter installed.
Thanks
2 answers Last reply Best Answer
More about laptop wireless turning switch battery power
  1. Best answer
    Check your power settings in the power options control panel -- whichever setting you are on, click "change plan settings," then "change advanced power settings." Under wireless adapter settings, power saving mode check to see that it is properly set.
    Here is some detail: http://support.microsoft.com/kb/928152
  2. Best answer selected by Quadrocopter.
Laptops Wireless Switch Battery Power Wireless Networking
