DSR-922 Power Loss
Forum Home Cinema Equipment : 4DTV Satellite - DSR-922 Power Loss
Archived from groups: alt.video.satellite.4dtv (More info?)
I have a new DSR-922. Worked fine for 2 weeks but now looses power
intermittently. After losing power it warms up and usually loses
power again. After a few times it powers up and works again for a few
hours then same thing happens. Bad power supply?? Breaker trip?
Any ideas. Any info is appreciated. Thanks, Steve
Sponsored Links
Check the System Status screen (Options 6-5) and see what version firmware it has and
if it says anything about the next ver. of the firmware. You may need to scroll that
screen to view all lines related to the firmware version.
Disconnect the LNB cables from the back panel and see how it acts. A problem in the
LNB cable may be causing this to happen.
<SRV> wrote in message news:2mep31tvj3p9da3fvv78j7ef9rme14mb5m@4ax.com...
Reply to Anonymous
Thanks for your help DRLev!
Says current ver is 000000EC
Target Ver 00000000
Will unplug the LNB's. The picture was great until yesterday. Then
the rebooting started and picture quality diminished. Lots of tiling
on DC and sparklies on Analogs. It did go from the 20's to the 50's
temperature wise here in the NE Ohio area. Is it possible a LNB is
wet from thawing ice and snow?? Talk to ya...Thanks, Steve
Reply to Anonymous
This kind of reminds me of the 922 I first had. It had some power
issues pretty much right out of the box (I don't recall the exact
details, but vaguely recall it would power off sometimes) when there was
a VCII module installed (kind of a necessity...), but once I pulled the
VCII out (per Motorola's(?) suggestion) there was no problem. Basically
an inadequate power supply.
The replacement 922 has worked fine for several years now (knock on
wood).
Reply to Anonymous
Tom's Hardware > Forum > Home Cinema Equipment > 4DTV Satellite > DSR-922 Power Loss
There are 611 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
