Tom's Hardware > Forum > Audio > Audio Technology > Meridian 207 CD player - replacement laser
Forum Audio : Audio Technology - Meridian 207 CD player - replacement laser
Archived from groups: rec.audio.tech (More info?)
I have a Meridian 207 CD player/pre-amp which has a faulty laser. It
has been back to Meridian who cannot repair it as they can no longer
supply a laser ( the machine is late 80's). Anyone know which transport
is used in this machine and where I may find either a replacement laser
or transport. Any help would be greatly appreciated. Please email me on
memu51@dsl.pipex.com
Sponsored Links
>or transport.
The 207 used a Philips drive, presumably a CDM4 or a CDM9. Meridian should
be able to supply this information.
A number of companies offer laser assemblies, either NOS or pull, check for
instance Dönberg Electronics http://www.donberg.ie/
Reply to Anonymous
Thanks very much for your help - will investigate further
Reply to Anonymous
laser
> >or transport.
should
check for
Hi
I have determined that the mechanism is a Philips CDM2/29 - Meridian
have assured me that after a world wide search they could not source
one - Dönberg appear to list it but Meridian say although some
suppliers do - they are not available!
Does another machine use this drive ? - perhaps I could fined a decent
used one!
Regards memu51
Reply to Anonymous
> laser
>>>or transport.
> should
> check for
> Hi
> used one!
> Regards memu51
Hello
you can look here:
http://www.bpt31.com/DIVERS/LasersEtOptiques.html
http://hifi.nn.gx.cn/well/wellview.html
http://www.grandata.co.uk/acatalog [...] S_124.html
http://www.componentesalonso.com/productos.asp
greetings
Joachim
Reply to Anonymous
Hi,
I have a compact disc meridian 207A . After 2 or 3 minutes it stop playing. Mearirian don't have any pieces for it.
Is someaone abble to help me.
My adress is r.castagna@lefort.com
Many tanks
Reply to Anonymous
There are 1040 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
