A little background first, I'm a bass player creating my own personal
monitoring solution for live performances. I've got it all worked out
bar one cable. I want a single cable to go between me and my amp which
will both send my bass signal to the amp whilst also feeding headphone
level audio back to me. I really want to use a single cable otherwise
I'll be tripping over the thing all night. Also, it needs to be a
robust as it will be stepped on a lot and have equipment run over it
from time to time! I'm considering something like the Mogami W3177.
More info here:
Does this sound viable? It is four core (I need three minimum to
provide mono bass one way and stereo headphones the other). It also
contains cotton which will give it the strength it needs. Bit worried
that it is a suspension microphone cable though. Perhaps that steel
re-inforcement could be a problem? I'm not expecting the cable to
match a high quality instrument cable but I'd just like the check its
not a silly choice before I go ahead and buy it. If anyone could
suggest an alternative that would be great too.
On 10 Apr 2005 03:24:00 -0700, panache_blues@hotmail.com (Darren
Dangerfield) wrote:
>Hi All,
>More info here:
>http://www.mogamicable.com/mogami_cab/micr_cables/stereo_miccab/stermicc.html
I glanced at the cable, it looks like it should do what you want.
One important parameter is to look at the capacitance, the 23.5pF/ft
figure. Muhtiply that by the length of the cable you'll want to use,
and compare it with your regular instrument cable (measure it or look
it up, however you can...). OTOH, having a couple of dB signal drop at
5kHz won't be nearly a noticable or objectionable on bass as it would
be on a bright-sounding guitar. but I'd try to make it for as low a
capacitance as I reasonably could. Ten feet will be no problem, but
100 feet may be.
Rereading above, you wrote W3177, you should really use the W3106
(which is what I at first thought you were asking about). Firstly, you
need to run separate grounds for your instrument and heaphones, (which
using three of the four inner conductors in the W3177, as you were
thinking about doing, would do), but also you need these in separate
shields, else the headphone signal may be picked up by the instrument
wire, especially at higher frequencies where it can give a feedback
path for oscillation (probably ultrasonic - you may not hear it, but
it could burn up some amplifiers).
The big thing to remember is that the instrument line and the
headphone line should be totally separate electrically, including
being in different shields. The three headphone lines don't really
need shielding except for the possibility that they may induce a
signal into the cable next to them.
The second and third cables are designed to be wired as "star quad"
balanced mic cables, but (except for the caveats above) you can use
these wires any way you want. Actually, I'd take advantage of the
star-quad configuration to reduce crosstalk - with the W3178, use the
top and bottom pair to connect to one headphone, and the left and
right pair to connect to the other. Do not tie together the common
grounds at the headphone end (you'll need to get rid of the usual
headphone TRS plug and the three-conductor headphone cord, and connect
these four wires directly to the two headphone drivers), and then
connect the headphone grounds and shield for the headphone cable
together only at the amplifier/mixer end of the cable. And of course
have the instrument cable go separately to the amp, as usual.
There's also the DIY idea using two cables and a few rolls of
electrical tape.
Thanks for the very complete reply. I tried to get hold of the W1306
cable but it was going to end up being a special order, not to mention
the fact that I'd need to buy an entire drum of it. Just too costly
really and I have a gig tomorrow! Anyway, I decide to go the 'Heath
Robinson' route and fix together two cables myself. Actually, someone
on another forum suggested feeding the guitar cable down a coiled
headphone cable. Interesting idea but I was worried about ending up
being pulled back towards my amp. In the end I used heatshrink to bond
together two cables, placing a couple of cm's of heatshrink about
every 12cm. The end result is excellent - very strong and flexible
too. Did take quite some time to do though so not for the
fainthearted.
P.s. I'm keeping your reply tucked away in case I ever come back to
this and want to go the starquad route so thanks again.
Regards.
Darren.
Ben Bradley <ben_nospam_bradley@frontiernet.net> wrote in message news:<2eki51l04gfean2eui84mbv6bm1q6ag4h0@4ax.com>...
> Dangerfield) wrote:
> >Hi All,
> >More info here:
> 100 feet may be.
> electrical tape.
> >Thanks.
> >Darren.
> http://mindspring.com/~benbradley
