Tom's Hardware > Forum > Audio > Audio Technology > John Bowers Active One HELP
Forum Audio : Audio Technology - John Bowers Active One HELP
Archived from groups: rec.audio.tech (More info?)
Hello,
I recently acquired a pair of John Bowers Active Ones,
serial number 359 and 360. Made in 1985.
They have an internal 300W Mosfet amp.
So I get them home, plug them in, run an RCA jack from
my preamp and get nothing - no sound at all.
One the back, they both have one small red light, and one small green
light, both are on.
When I first turn them on just the red light is on, then I turn it off,
turn it back on a litle bit later, and they are both on.
1) I open the case and look at the amp boards and it looks like the
preamp board (tone control I guess) has a small black smoky looking
spot, so I'm assuming it's fried?
2) The power supply says 220V, and it was sold originally in Germany,
could it be a power supply problem? Could US power have fried the amp?
It uses a computer style three prong AC cord.
I ran the speaker connectors out the back and through an external
crossover and all the drivers are working perfectly and sound great
with my tube amp so it's not a problem with the drivers.
All the fuses are fine.
Any help or suggestions would be greatly appreciated.
Thanks,
Mike
Sponsored Links
> Germany, could it be a power supply problem? Could US power
> have fried the amp?
A beautiful example of a usenet question carefully avoiding the single
most important item of information, the one that is required to try to
post a useful comment.
Just what kind of mains power are you feeding them now?
> Mike
Kind regards
Peter Larsen
* My site is at: http://www.muyiovatki.dk *
Reply to Anonymous
- 0 +
I think you might have mistook my plain old fashioned ignorance for
"carefully avoiding important information."
I ran a three prong AC cord from the wall sockt of my USA home into the
speakers,
and they powered up. This is how I usually feed things with powers,
from
the magic electricity that flows from my walls.
I don't know much about power supply, and don't use any fancy external
line condiitioners, adaptors, etc.
I would not even be asking the question if I could find some
information on these
speakers, but I don't think many were made, and there is scarce little
info online
about them, I was hoping someone who owns or owned a pair could shed
some
light on the red and green lights on the back,
red meaning stop and green meaning go - I'm a little confused.
I can just insert a crossover and enjoy the speakers without the amps,
so all is not lost.
Thanks,
Mike
Reply to Mike
<mike@dlowracing.org> wrote in message
news:1113627524.615163.306930@o13g2000cwo.googlegroups.com...
> Hello,
> light, both are on.
* Could be.
* Lets see..... you apply 115volts AC to a device which requires 220 volts
AC to make it work.. And it doesn't ! What a surprise. You'll need a step
up power transformer to convert your 115v(approx) supply to 230volt(approx)
to make the amps work. And that's assuming that you haven't damged the
internals.
Reply to Anonymous
news:1113681115.183595.161880@l41g2000cwc.googlegroups.com...
> speakers,
> from
Just as well you are not in a 220v country plugging in a 110v device - then
the black smokey bit may be substantially bigger.
geoff
Reply to Anonymous
So you noticed the required voltage, but thought you'd try it on a
110v outlet anyway? Duh!
Yes. It may seem paradoxical, but too low a supply voltage can cause
overheating, sometimes catastrophic overheating.
Reply to Anonymous
There are 519 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
