PC keeps forgetting my connection. Help!
CaptainTom
1,563
I just built this desktop and everything seems to be working well accept the connection I want saved on my computer. Every time I turn my computer on I have to select the conection manually and enter the WEP key. How do I fix this?
-I am using Windows 7
-My wifi card is a USB EDIMAX
If on a Home Network after entering a WPA2 network key to access your router and the web, There is a automatically connect button which one would select before clicking the connect button after typing your key which then will remember that key for future notice.
dannyj94
11
