Tom's Hardware > Forum > Audio > Audio Technology > HELP: Preouts on Audio Processor
Forum Audio : Audio Technology - HELP: Preouts on Audio Processor
Archived from groups: rec.audio.tech,rec.audio.car (More info?)
Hi,
I have an existing unit that uses a TDA7348 Audio Processor.
http://www.st.com/stonline/books/ascii/docs/1551.htm
The problem is that this unit doesn't have Pre-Outs. I have connected
pre-outs directly from the TDA7348 outputs and this works fine with
two issues:
1. When trying to connect a Line Driver (Phoenix Gold) and turning up
the volume, it looks like there is a breakdown somewhere and no audio
is emitted. If it is low volume you can hear it, but the moment you
try and increase the gain on the line driver it stops. (Line drive
works fine when another device is connected to it)
2. RF Noise is entering, like Mobile Phone Communication and engine
noise sometimes (like a soft whine) but not always
Is there a simple circuit that I can added from the output of the
TDA7348 to the preouts to prevent Number 1 and if possible Number 2?
Ultimate goal is to get a clean signal to be able to run it through
the Line Driver to increase the signal, before hitting the amp.
Any help will be appreciated.. Thanks
Sponsored Links
There are 1242 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
