Which is the best Cable modem / NIC combo? I currently have a d-link standard cheap 10/100 NIC with a Terayon Pro Cable Modem... i think there has to be a better combo out there... right?
And also, what if i were to use one of those new 1000Mbps NIC's... are they better than the 10/100 NIC's? In which ways are they better or worse than the 10/100 NIC's? Are there any 1000Mbps (routers + hub's) boxes out there? If so, would it be worth it with a new cable modem? Or is my terayon pro good enough?
If it may help, my cable service provider is Adelphia, and I live in the Los Angeles, CA area... specifically, near El Monte.
Terayon modems are considered one of the best available as for the nic the one you have is fine there are a few others notably a 3com model that do some of the processing onboard but this just helps your cpu a little .. since cable dosent exceed 10mbps there isn't much room for improvement other than changing from adelphia to a better provider like optimum online ( they run at 8 MB down and 1 MB up on avg.)
lagger
<b><font color=blue>Checking under my North<font color=red> AND</font color=red> South bridges for <font color=green>Trolls</font color=green></font color=blue>
